Dear all,
I was create a layout. but i cant to see the drawing in model view, i can see the drawing in print preview only, but i want to show the drawing in layout also, so what to do ??
With model space active, try
UCS > World
PLAN > World
Zoom > Extents
If that doesn't work, attach the drawing.
Did you create the drawing in a layout ?
Thanks for your replay,
Mr.Nestly i did thats but still i can't to see that..
Mr.Steven i am not. i created in model . and show it layout.. (i was create 10 viewport in one layout)
You are double clicking into a Viewport in order to make it active, then Zooming Extents, and your modelspace appears empty?
Change the perspective to an Isometric view, then change your visualstyle in your viewport to CONCEPTUAL, zoom extents again, and search around the edge of your screen for any small
entities which are digital flotsam. This is the most common cause of this problem.
Something unintentional which is so far from the rest of your drawing that it screws up your Zoom Extents game plan, by including it.
If none of the suggestions solve the problem, attach a sample drawing with the problem.
Right click the viewport and make sure "Display Viewport Objects" is set to Yes.
As nestly suggested, a drawing would help clear things up.
THANKS Mr.SLW210
my viewport display setting was "No" i changed to " yes " i can see now..
Thanks to all ..........
Have a nice day ........ :):D
