CIVILSUE Posted April 15, 2014 Posted April 15, 2014 Can someone tell me the steps to edit the alignment style properties to center the station label on the centerline/tick mark. I've read it takes several steps but don't understand. I'm very new to Civil 3d 14 without training! These style settings are killing me!!!! Thanks! Sue Quote
BlackBox Posted April 15, 2014 Posted April 15, 2014 Welcome to CADTutor. Firstly, the Standard Label Style is setup to automagically be aligned perpendicularly with your Alignment, so if your custom Label Style is not being oriented properly, consider instead making a copy of the Standard Label Style, and modifying text size, style, layer, etc. Without more information, the best I can offer you at this point, is to look closely at your Label Style's Properties, specifically, the General tab, Behavior node, Orientation Reference property and set it to 'Object'. Otherwise, perhaps you've added a rotation value under Layout tab? *not sure* Cheers Quote
