rlshound Posted April 16, 2014 Posted April 16, 2014 Hello, I've created a template drawing and am continuing with our new survey environment creating Point Styles for our field codes. Is it possible to import Point Styles? Your help would be appreciated, rlshound Quote
BlackBox Posted April 16, 2014 Posted April 16, 2014 In Civil 3D 2012 and newer... Go to the Manage RibbonTab, Styles RibbonPanel, Import RibbonButton. Quote
BlackBox Posted April 17, 2014 Posted April 17, 2014 Awesome BlackBox ! Thanks!! That is kind of you to say, rlshound; I'm happy to help. Quote
JerryG Posted April 23, 2014 Posted April 23, 2014 Another simple way if you have another dwg open, is to copy a point from any drawing. Paste it into the new drawing but before you hit enter hit Esc key. The style will now be in the drawing. This works for just about any object with a style applied. Quote
BlackBox Posted April 23, 2014 Posted April 23, 2014 Another simple way if you have another dwg open, is to copy a point from any drawing. Paste it into the new drawing but before you hit enter hit Esc key. The style will now be in the drawing. This works for just about any object with a style applied. Be mindful that this can also easily cause one to have to recover their drawing. If you want an Object available in another drawing, DREF, XREF, use LandXML to export/import, or promote a DREF. If you only want a particular Style, I strongly suggest the method I note above, as it allows multiple Styles, and Style types to be brought in at once. Otherwise, you can drag a Style from one drawing to another via Propsector. Quote
BIGAL Posted April 24, 2014 Posted April 24, 2014 I second using import styles dont forget all the other stuff like blocks that are attached to a style. If I remeber correct Aeccimportstyles. Quote
JerryG Posted April 24, 2014 Posted April 24, 2014 Good to know guys - I think I will start using the Manage, Styles option as I have indeed had a few crash. I have never liked using Prospector since it seams to take such a long time to drag and drop the style into the new drawing. Works ok for one style I guess but often I need multiple ones. Thanks!! Quote
BlackBox Posted April 24, 2014 Posted April 24, 2014 Good to know guys - I think I will start using the Manage, Styles option as I have indeed had a few crash. I have never liked using Prospector since it seams to take such a long time to drag and drop the style into the new drawing. Works ok for one style I guess but often I need multiple ones. Thanks!! You're welcome, JerryG; we're happy to help. Quote
rlshound Posted April 25, 2014 Author Posted April 25, 2014 Thanks to all for your input...Have a good week end! rlshound Quote
JerryG Posted April 28, 2014 Posted April 28, 2014 Been using the stated method now for the last week and it works great! Always nice to learn something new..... Thanks Guys! Quote
