glen huxtable Posted April 19, 2014 Posted April 19, 2014 I need to use my old Autocad LT 95 which uses R13 to edit my designer's archicad drawings. He can save them as Autocad 2004 I believe. DWG Trueview is not able to edit and input dimensions,which I need . OR is there another cad program (freeware) that could do simple editing of an Autocad 2004 file? I run XP on the system that will sit on the jobsite. Quote
Dana W Posted April 19, 2014 Posted April 19, 2014 Try Draftsight. It is a free AutoCad LT clone, from Dassault systems. Link here. TrueView Will convert drawings back, but unfortunately only to 2004. Quote
eldon Posted April 20, 2014 Posted April 20, 2014 I think that DWG Trueview can convert back to R14. But try AutoCAD 360, which can save back to R12 DXF. Quote
Dana W Posted April 20, 2014 Posted April 20, 2014 I think that DWG Trueview can convert back to R14. But try AutoCAD 360, which can save back to R12 DXF. I double checked, TrueView can go back to 2000. Quote
eldon Posted April 20, 2014 Posted April 20, 2014 I must have a different version to you then. I can save back to R14. Quote
Dana W Posted April 20, 2014 Posted April 20, 2014 I must have a different version to you then. I can save back to R14.2014 Version 1.18.0.0 here.Also, for some reason 2000 cannot be converted in place. There has to be a target folder of the user's choosing. I guess they eventually start dropping the oldest versions from the conversion. I wonder if the marketing department was at that meeting? Quote
eldon Posted April 20, 2014 Posted April 20, 2014 It looks like the OP will have to fall back on AutoCAD 360 then. One can dimension in AutoCAD 360. Quote
glen huxtable Posted April 23, 2014 Author Posted April 23, 2014 draftsight seems to be way to go Quote
Dana W Posted April 23, 2014 Posted April 23, 2014 It will work. You will find that it looks and works fundamentally just like AutoCad LT, but the options, names, and button icons are a little different here and there. I think Draftsight still uses the 2007 AutoCad file format, not sure. The resulting dwg files can be opened in AutoCad but the user will see a warning about the drawing not being created by a "Trusted" Autodesk product. Quote
