Measure the length of curved line from one point to another.
Here I have got a network. I just want to measure the length of the green bend line starting from the blue box to the point before it becomes with parallel with red line (As find in attached figure).
Similarly also the length where two red and one green line parallel.
Also the length of single red line as mentioned on figure.
I use a technique of using command Trim but it taking time and network is huge.
Is there any simple way to count their length using AutoCAD built-in commands?
You could use the MEASUREGEOM command, but you have to pick the points along the entity, like you are redrawing it.
We use a 3rd party command in ToolPac that lets you select an entity, and pick two points on the entity.
