billy68 Posted April 23, 2014 Posted April 23, 2014 Is there a script / lisp routine which will open up multiple acad drawings in selected batches and then modify the text font style across a drawing without affecting the height and justification properties. It would also be useful if the same script file could allow a generic note to be added to each drawing at the same given location. Thanks Quote
ReMark Posted April 23, 2014 Posted April 23, 2014 Enough with the multiple postings in different forums. It just causes confusion down the road. Click on the link below for a script that will change a drawing's text style. That's your starting point for batch processing a folder full of drawings. http://becadsmart.blogspot.com/2012/04/change-text-style-script-autocad.html Use the Copy to Drawing lisp routine by Lee Mac to add your note to multiple drawings. http://lee-mac.com/copytodrawing.html Quote
RickDee Posted March 2, 2021 Posted March 2, 2021 But how do you run the script with the Copy to Drawing lisp routine? Quote
RickDee Posted March 2, 2021 Posted March 2, 2021 18 minutes ago, RickDee said: But how do you run the script with the Copy to Drawing lisp routine? Problem: I have around 100 seperate dwg files (A4 schematics), but i want to change the text Style of each dwg. I dont want to open 100 dwg files by hand, to change the text Style. Would be faster to use a script for that. Quote
Tharwat Posted March 2, 2021 Posted March 2, 2021 45 minutes ago, RickDee said: But how do you run the script with the Copy to Drawing lisp routine? https://autolispprograms.wordpress.com/how-to-load-an-autolisp-program/ Quote
