Hi,
i have been experimenting with short cut menus a little.
i was hoping someone could explain it a little or point me in the direction for a good tutorial on it, i have managed to create short cut menus but cant get access to it unless i basically delete everything from the default menu ( of course i have copied it before deleting) and then adding my commands to it. this is great as i never use the standard shortcut anyway and my RH button is set to enter. so i have set my RH button to show the default shortcut menu after i hold it down for 100millisecs so thats great but now i want to modify the shortcut menu that you access when shift and mouse button 2 & 3 and also when ctrl is selected.
well shift + rh click with remain my snaps menu but that should leave room for 3 more short cut menus.
so i have created my short cut menus and went to the mouse button nodes in the cui and tried to modify “shift + button 3” however I don understand the macro and how to set it to open my particular short cut menu?
I looked at the snap macro from button 2 hoping to modify it
$P0=SNAP $p0=*
[\code]
I tried
[code]
$P530=SNAP $p530=*
[\code]
Then
[code]
$P530=Default Menu Shift3 $p530=*
[\code]
530 being the POP no of the short cut menu i want to use and 'Default Menu Shift3'
But with no luck? I now I am doing it wrong but cant see how to tell autocad what shortcut menu I want when mouse buttons are clicked?
thankk you for any help,
cheers,
col
Hi
i tried
$p1=*
and i showed me file menu floating so i thought
$p530=*
would work but nothing happens????
i go it to work, you have to refrence the short cut menu after the pop 3 line then
eg
$P0=SNAP $p0=*
becomes
$P0=mymenu $p0=*
the P0 reference is for the default shorct cut menu $P0=mymenu loads it and
$p0=* then displays the menu
Col.
eg
$P0=SNAP $p0=*
becomes
$P0=mymenu $p0=*
Col.
