Hi,
Is it possible to create commands ith autocad?
i am currentyl creating drop down menus for inserting our standard block. i do like tool palettes but we have a hundreds of standard blocks and these will neve change so creating custom menus seems the best solution.
i have looked in help and i have found how to create the menus but not the actual commands?
Many thanks for any help.
col
Hey,
If you are trying to link a button to a lisp file which is used to load a certain block you have created use this.
^C^C(load "insert-block");insert-detcall-block
Basically the (load "insert-block") is it loading the lisp routine. Then the second part is the actual command within the lisp that will run the code you have for the block for it to be inserted.
Are you using a lisp for it? and what version of autocad are you using. I have made special menus for certain block I use all the time and have found that a lisp is the easiest way to do it. Because you can copy and paste the code for each one and just change the command line and the block it is searching for.
I have attached a the code I use for mine (autocad 09)
;---DETAIL BUBBLE---
(defun c:insert-detbub-block (/ layerset)
(setq layerset (getvar "clayer"))
(setvar "clayer" "35")
(setq scaleset(/ 1 (getvar "cannoscalevalue")))
(setvar "ATTDIA" 0)
(setq ins-pt (getpoint "\nSelect Insertion Point: <0,0>"))
(if (= nil ins-pt) (setq ins-pt (list 805 553)) )
(command "-insert" "detail bubble" ins-pt scaleset scaleset "0")
(command "explode" (entlast))
(setvar "ATTDIA" 1)
(setvar "clayer" layerset)
) ;defun
I have used it this way and made seperate files for each block.
Hi,
col
Here is some VBA boilerplate code. It creates a few menus, and attaches a VBA macro to be called when the menu item is selected.
You might just wish to create an "Insert": type subroutine, and just pass it different parameters
Sub Main()
   Dim retMenu As AcadPopupMenu
   Dim retMenuItem As AcadPopupMenuItem
   Const MainMenuName As String = "My&Menu" ' add an Ampersand in front of letter to make it a Hotkey
   Const SubMenuName As String = "My&SubMenu"
   ' either add new, or return existing main menu Item
   Set retMenu = AddMainMenu(MainMenuName) '' add (or GET) main menu item
   ' add some sub menu item to our main menu
   For I% = 1 To 4
     Set retMenuItem = AddMainMenuItem(retMenu, SubMenuName & Str$(I%), "TestSub")
   Next '
End Sub
Private Function AddMainMenu(strMenuName As String) As AcadPopupMenu
   ' adds a main menu to acad menus, or returns an existing menu with the same name
   Dim currMenuGroup As AcadMenuGroup
   Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item("ACAD")
   For I = 0 To currMenuGroup.Menus.Count - 1
       If currMenuGroup.Menus(I).Name = strMenuName Then
           Set AddMainMenu = currMenuGroup.Menus(I)
           Exit Function
       End If
   Next
   ' if we're still here, we didnt find the menu, so we'll add one
   Set AddMainMenu = currMenuGroup.Menus.Add(strMenuName)
    ' Display the menu on the menu bar
   AddMainMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.Count + 1)
End Function
Private Function AddMainMenuItem(objMenu As AcadPopupMenu, strMenuItem As String, strMacroName As String) As AcadPopupMenuItem
   ' adds a sub menu item to the passed menu object
   ' the "strMenuIte" param is the name of ther menu, per VB xconvention, embed an ampersand "&"
   ' before the letter you want to be a hotkey
   ' The "strMacroName" is the name of the Subroutine you want called when the menu is selected
   Dim openMacro As String
   openMacro = "-VBARUN " & strMacroName & " " ' add a space to enmnu item to emulate the ENTER key]'
   Set AddMainMenuItem = objMenu.AddMenuItem(objMenu.Count + 1, strMenuItem, openMacro)
End Function
Sub TestSub()
   ' name of routine to call when menu item is selected
   MsgBox "your menu was just selected"
End Sub
You can create your own menus and use slides this is like tool palettes but you write the code, A good example is the hatch pattern which pop up and you choose from the picture or the name
Serach here for "Insert blocks via toolbars" is the same question your asking there is an example picture.
thank you everyone, i have thought about this a bit and instead of making 10 or so menus/sub menus which i was intending to do and possible loading and unloading of menus depending on the aluminium system we are using at the time i think i will set 1 macro to insert all blocks, pausing for user input for the block name and rotation only and then set up the support paths in options.
thanks for everybodys help
col.
