byron771 Posted May 1, 2014 Posted May 1, 2014 (edited) Hi, I am new to the forum and have little experience with 3d modelling. I have been provided with a wireframe model of a train embankment for a job i am on. I would like to be able to quickly produce a x-section view of the embankment at any desired chainage. Can someone please explain how to do this? Thanks NX3 - Civil - Existing Ground - Triangles.dwg Edited May 1, 2014 by byron771 Quote
Murph_map Posted May 1, 2014 Posted May 1, 2014 Your dwg was saved down to a dumb AutoCAD dwg. You should use Autocad civil3d and the civil3d dwg otherwise there is no "quick" way to get the cross sections. Quote
byron771 Posted May 1, 2014 Author Posted May 1, 2014 Thanks. I will give it a go and let you know if it works. Quote
