Guest Posted May 1, 2014 Share Posted May 1, 2014 Hi , i am trying to extract station and elevetion from 3d polyline to txt file Important : For the station i need only Horizontal distanse not slope distanse (i need this file to use it for cross sections) This is an old code i try to change it but fail !! I attach two export files for example (defun c:sz (/ ent fh fn hnd itm num obj pnt sset v vexx) ;; helper to get 3dpoly coordinates (defun 3dpoly-verts (en / elist lst vex) (if (member "AcDb3dPolyline" (mapcar 'cdr (entget en))) (progn (setq vex (entnext en)) (setq elist (entget vex)) (while (= (cdr (assoc 0 elist)) "VERTEX") (setq lst (cons (trans (cdr (assoc 10 elist)) 1 0) lst)) (setq vex (entnext vex)) (setq elist (entget vex)) ) ) ) (reverse lst) ) ;;________________________________________________;; (setq sset (ssget '((-4 . "<OR")(0 . "POINT") (0 . "POLYLINE")(-4 . "OR>")))) (if sset (progn (setq itm 0 num (sslength sset)) (setq fn (getfiled "Αποθήκευση αρχείου station,Z" "" "txt" 1)) (if (/= fn nil) (progn (setq fh (open fn "w")) (while (< itm num) (setq hnd (ssname sset itm)) (setq ent (entget hnd)) (setq obj (cdr (assoc 0 ent))) (cond ((eq obj "POINT") (setq pnt (cdr (assoc 10 ent))) (setq pnt (trans pnt 0 1));;**CAB (write-line (strcat (rtos (distance pnt pnt) 2 3) "," ; i don't know how to give the distanse (rtos (caddr pnt) 2 3)) fh) ) ((= obj "POLYLINE") (setq v hnd) (setq vexx (3dpoly-verts v )) (foreach pnt vexx (write-line (strcat (rtos (distance pnt pnt) 2 3) ","; i don't know how to give the distanse (rtos (caddr pnt) 2 3)) fh) ) ) (t nil) ) (setq itm (1+ itm)) ) (close fh) ) ) ) ) (princ) ) (princ) test1(open poly).txt test1(close poly).txt test.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 2, 2014 Share Posted May 2, 2014 If you dont have any curves this will work, you will though have to do the distance bit from the xy of the point just remember pythagoras thereom. ; pline co-ords example (defun getcoords (ent) (vlax-safearray->list (vlax-variant-value (vlax-get-property (vlax-ename->vla-object ent) "Coordinates" ) ) ) ) (defun co-ords2xy () ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z (setq numb (/ (length co-ords) 2)) (setq I 0) (repeat numb (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) )) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 2)) ) ) ; program starts here (setq co-ords (getcoords (car (entsel "\nplease pick pline")))) (co-ords2xy) ; list of 2d or 3d points making pline ; list xy is 2d or 3d pts Quote Link to comment Share on other sites More sharing options...
hmsilva Posted May 2, 2014 Share Posted May 2, 2014 Hi , i am trying to extract station and elevetion from 3d polyline to txt file Important : For the station i need only Horizontal distanse not slope distanse (i need this file to use it for cross sections) Hi prodromosm, Just a thought, I think it's time for you to start trying to write your own codes. This demo it's just a different approach... Try to understand the code, it's written in a simple way, and I think it will be easy to understand, if not, just asks... (defun c:demo (/ e fn fo lst par parpt poly pos pre pt s) (prompt "\nSelect a 3DPolyline to extract Stations and Elevations to txt file: ") (if (and (setq s (ssget "_+.:E:S" '((0 . "POLYLINE") (-4 . "&") (70 . ))) (setq fn (getfiled "Enter the output filename:" (getvar 'DWGPREFIX) "txt" 1)) (setq pre (strcase (getstring "\nEnter station prefix:"))) );; and (progn (setq poly (vlax-ename->vla-object (ssname s 0)) e (fix (vlax-curve-getEndParam poly)) pos 0 par 0 lst nil );; setq (while (/= par (1+ e)) (setq pt (vlax-curve-getPointAtParam poly par) pos (1+ pos) );; setq (if (not parpt) (setq lst (cons (strcat pre (itoa pos) "," "0.000," (rtos (caddr pt) 2 3)) lst) parpt pt );; setq (setq lst (cons (strcat pre (itoa pos) "," (rtos (distance (list (car pt) (cadr pt)) (list (car parpt) (cadr parpt))) 2 3) "," (rtos (caddr pt) 2 3)) lst) parpt pt );; setq );; if (setq par (1+ par)) );; while (if lst (progn (setq lst (reverse lst) fo (open fn "w") );; setq (foreach l lst (write-line l fo) );; foreach (close fo) );; progn );; if );; progn );; if (princ) );; demo HTH Henrique Quote Link to comment Share on other sites More sharing options...
Guest Posted May 2, 2014 Share Posted May 2, 2014 Thank you hmsilva.I have a question. if i want to export more data from the polyline how can i do it? For examle after the between distanse colum i want to add a distanse from the begening colum and the the elevetion D1,0.000,0.000,5.568 D2,36.776,36.776,6.221 D3,10.089,46.865,5.429 D4,13.984,60.849,5.519 D5,16.574,77.423,5.407 Quote Link to comment Share on other sites More sharing options...
hmsilva Posted May 2, 2014 Share Posted May 2, 2014 Thank you hmsilva.I have a question. if i want to export more data from the polyline how can i do it? For examle after the between distanse colum i want to add a distanse from the begening colum and the the elevetion You're welcome, prodromosm! Try (defun c:demo (/ acdist e fn fo lst par parpt pdist poly pos pre pt s) (prompt "\nSelect a 3DPolyline to extract Stations and Elevations to txt file: ") (if (and (setq s (ssget "_+.:E:S" '((0 . "POLYLINE") (-4 . "&") (70 . ))) (setq fn (getfiled "Enter the output filename:" (getvar 'DWGPREFIX) "txt" 1)) (setq pre (strcase (getstring "\nEnter station prefix:"))) );; and (progn (setq poly (vlax-ename->vla-object (ssname s 0)) e (fix (vlax-curve-getEndParam poly)) pos 0 par 0 acdist 0.0;; <--Start accumulated distance lst nil );; setq (while (/= par (1+ e)) (setq pt (vlax-curve-getPointAtParam poly par) pos (1+ pos) );; setq (if (not parpt) (setq lst (cons (strcat pre (itoa pos) "," "0.000,0.000," (rtos (caddr pt) 2 3)) lst) parpt pt );; setq (setq lst (cons (strcat pre (itoa pos) "," ;; store the partial distance at the pdist variable (rtos (setq pdist (distance (list (car pt) (cadr pt)) (list (car parpt) (cadr parpt)))) 2 3) ;; adding acdist and pdist, and store the accumulated distance at acdist variable "," (rtos (setq acdist (+ acdist pdist)) 2 3) "," (rtos (caddr pt) 2 3)) lst) parpt pt );; setq );; if (setq par (1+ par)) );; while (if lst (progn (setq lst (reverse lst) fo (open fn "w") );; setq (foreach l lst (write-line l fo) );; foreach (close fo) );; progn );; if );; progn );; if (princ) );; demo HTH Henrique Quote Link to comment Share on other sites More sharing options...
Guest Posted May 2, 2014 Share Posted May 2, 2014 Thank you hmsilva. Quote Link to comment Share on other sites More sharing options...
hmsilva Posted May 2, 2014 Share Posted May 2, 2014 You're welcome, prodromosm Henrique Quote Link to comment Share on other sites More sharing options...
Guest Posted May 3, 2014 Share Posted May 3, 2014 Hi , hmsilva can you make a change the post #3 code to export files like the attach. 1) select the start point (dimension 0.000) 2) I whant the minus (-) to be allways to the left side of the direction of polyline look the attach test1.dwg from 2 to 1.txt from 1 to 2.txt Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 4, 2014 Share Posted May 4, 2014 A work in progress 1 program a lot of answers. Like Hmsilva feel free to use bits of it. ; pline example listing various properties like pts and lengths ; By Alan H 2014 (defun getcoords (ent) (vlax-safearray->list (vlax-variant-value (vlax-get-property (vlax-ename->vla-object ent) "Coordinates" ) ) ) ) (defun getlength (ent) (vlax-get-property (vlax-ename->vla-object ent) "Length") ) (defun co-ords2xy () ; convert now to xyz (setq xyprin "\n") ; new line (if (= xyz 2) (progn (setq I 0) (repeat (/ len 2) (setq x (nth i co-ords)) (setq y (nth (+ I 1) co-ords)) (setq xy (list x y)) (setq xyprin (strcat xyprin "\n" (rtos x 2 2) "," (rtos y 2 2 ))) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 2)) ) ; repeat ) ; progn ) ; if (if (= xyz 3) (progn (setq xyprin "\n") ; new line (setq I 0) (repeat (/ len 3) (setq x (nth i co-ords)) (setq y (nth (+ I 1) co-ords)) (setq z (nth (+ I 2) co-ords)) (setq xy (list x y z)) (setq xyprin (strcat xyprin "\n" (rtos x 2 2) "," (rtos y 2 2 ) "," (rtos z 2 2 ))) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 3)) ) ; repeat ) ; progn ) ; if ) ; defun ; program starts here (setq ent (car (entsel "\nPlease pick pline"))) (setq co-ords (getcoords ent )) (setq len (length co-ords)) ; check for odd even list 2d v's 3d (setq oddeven (- (fix (/ len 2.0))(/ len 2.0))) (if (= oddeven 0.5) (setq xyz 3) ; 3d pline (setq xyz 2) ; 2d pline ) (setq numvert (/ len xyz)) (princ (strcat "\nNumber of vertices " (rtos numvert 2 0))) (co-ords2xy) (princ xyprin) ; prints out points co-ords (setq pllen (getlength)) (princ (strcat "\nActual length of pline " (rtos pllen 2 2))) ; to be done (princ segment lengths 2d) ; tobe done (princ segment lengths 3d) if different ; to be done (princ angle of segments) ; to be done (princ delta angle of segments (princ) Quote Link to comment Share on other sites More sharing options...
Guest Posted May 17, 2014 Share Posted May 17, 2014 Hi , hmsilva can you make a change to the code in the post #5 in the post #5 we have this results D1,0.000,0.000,5.568 D2,36.776,36.776,6.221 D3,10.089,46.865,5.429 D4,13.984,60.849,5.519 D5,16.574,77.423,5.407 Thank you Can you change it to export only 0.000,5.568 36.776,6.221 46.865,5.429 60.849,5.519 77.423,5.407 Quote Link to comment Share on other sites More sharing options...
hmsilva Posted May 17, 2014 Share Posted May 17, 2014 Hi , hmsilva can you make a change to the code in the post #5in the post #5 we have this results Thank you Can you change it to export only Hi prodromosm, as I had said earlier "I think it's time for you to start trying to write your own codes." So, I did add some annotations to the code you want to modify, it's an easy task, try yourself to modify the code, if you have any questions, just asks... (if (not parpt);; tests for parpt existence, if not, initializes the lst list with the first string (setq lst (cons;; to add elements to the lst list (strcat;; to concatenate multiple strings in one pre;; first sting element, the prefix i.e D (itoa pos);; the prefix index "," "0.000,0.000,";; second and third string elements, the partial and accumulated distances (rtos (caddr pt) 2 3);; the fourth string element, the Z value );; strcat lst);; cons parpt pt;; sets parpt with the pt value );; setq ;; if the lst list is already initialized, just continues to add strings to the lst list (setq lst (cons;; to add elements to the lst list (strcat;; to concatenate multiple strings in one pre;; first sting element, the prefix i.e D (itoa pos);; the prefix index ",";; the first comma separator ;; store the partial distance at the pdist variable (rtos (setq pdist (distance (list (car pt) (cadr pt)) (list (car parpt) (cadr parpt)))) 2 3) ",";; the second comma separator ;; the third string element adding acdist and pdist, ;; and store the accumulated distance at acdist variable (rtos (setq acdist (+ acdist pdist)) 2 3) ",";; the third comma separator (rtos (caddr pt) 2 3);; the fourth string element, the Z value );; strcat lst);; cons parpt pt;; sets parpt with the pt value );; setq );; if HTH Henrique Quote Link to comment Share on other sites More sharing options...
Guest Posted May 17, 2014 Share Posted May 17, 2014 Hi , hmsilva can you help me with this error i try to change the code to export only 0.000,5.56836.776,6.221 46.865,5.429 60.849,5.519 77.423,5.407 But now i can not export any file !!! (defun c:demo (/ e fn fo lst par parpt poly pos pre pt s) (prompt "\nSelect a 3DPolyline to extract Stations and Elevations to txt file: ") (if (and (setq s (ssget "_+.:E:S" '((0 . "POLYLINE") (-4 . "&") (70 . ))) (setq fn (getfiled "Enter the output filename:" (getvar 'DWGPREFIX) "txt" 1)) );; and (progn (setq poly (vlax-ename->vla-object (ssname s 0)) e (fix (vlax-curve-getEndParam poly)) pos 0 par 0 lst nil );; setq (while (/= par (1+ e)) (if (not parpt) (setq lst (cons (strcat "," "0.000," (rtos (caddr pt) 2 3)) lst) parpt pt );; setq (setq lst (cons (strcat "," (rtos (setq acdist (+ acdist pdist)) 2 3) "," (rtos (caddr pt) 2 3)) lst) parpt pt );; setq );; if (setq par (1+ par)) );; while (if lst (progn (setq lst (reverse lst) fo (open fn "w") );; setq (foreach l lst (write-line l fo) );; foreach (close fo) );; progn );; if );; progn );; if (princ) );; demo Thanks Quote Link to comment Share on other sites More sharing options...
hmsilva Posted May 17, 2014 Share Posted May 17, 2014 But now i can not export any file !!! Hi prodromosm, A quick fix... (defun c:demo (/ acdist e fn fo lst par parpt pdist poly pos pre pt s) (prompt "\nSelect a 3DPolyline to extract Stations and Elevations to txt file: ") (if (and (setq s (ssget "_+.:E:S" '((0 . "POLYLINE") (-4 . "&") (70 . ))) (setq fn (getfiled "Enter the output filename:" (getvar 'DWGPREFIX) "txt" 1)) ; no prefix ;|(setq pre (strcase (getstring "\nEnter station prefix:")))|; );; and (progn (setq poly (vlax-ename->vla-object (ssname s 0)) e (fix (vlax-curve-getEndParam poly)) pos 0 par 0 acdist 0.0 lst nil );; setq (while (/= par (1+ e)) (setq pt (vlax-curve-getPointAtParam poly par) pos (1+ pos) );; setq (if (not parpt) (setq lst (cons (strcat ;|pre (itoa pos) "," "0.000,"|; "0.000," (rtos (caddr pt) 2 3)) lst) parpt pt );; setq ;; the pdist variable is needed to the accumulated the distance (setq pdist (distance (list (car pt) (cadr pt)) (list (car parpt) (cadr parpt))) lst (cons (strcat ;|pre (itoa pos) "," (rtos (setq pdist (distance (list (car pt) (cadr pt)) (list (car parpt) (cadr parpt)))) 2 3) ","|; (rtos (setq acdist (+ acdist pdist)) 2 3) "," (rtos (caddr pt) 2 3)) lst) parpt pt );; setq );; if (setq par (1+ par)) );; while (if lst (progn (setq lst (reverse lst) fo (open fn "w") );; setq (foreach l lst (write-line l fo) );; foreach (close fo) (startapp "notepad" fn);; added to open the new txt file );; progn );; if );; progn );; if (princ) );; demo Untested, I have no AutoCAD with me right now... Henrique Quote Link to comment Share on other sites More sharing options...
Guest Posted May 17, 2014 Share Posted May 17, 2014 With or without AutoCAD you are the best my fried !!! Thanks Quote Link to comment Share on other sites More sharing options...
hmsilva Posted May 17, 2014 Share Posted May 17, 2014 You're welcome, prodromosm! See the differences between your code and mine, and try to find out why your code didn't worked as expected. Cheers Henrique Quote Link to comment Share on other sites More sharing options...
Guest Posted September 9, 2014 Share Posted September 9, 2014 Hi hmsilva is it possible to update to export data using a center line . look the attach file and you will understand test1.dwg export data.txt Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted September 9, 2014 Share Posted September 9, 2014 prodromosm, try this revision... (defun c:demo (/ acdcp acdist cp e fn fo lst osm par parpt pdist poly pos pre pt s) (vl-load-com) (setq osm (getvar 'osmode)) (setvar 'osmode 1) (prompt "\nSelect a 3DPolyline to extract Stations and Elevations to txt file: " ) (if (and (setq s (ssget "_+.:E:S" '((0 . "POLYLINE") (-4 . "&") (70 . ))) (setq fn (getfiled "Enter the output filename:" (getvar 'DWGPREFIX) "txt" 1 ) ) ; no prefix ;|(setq pre (strcase (getstring "\nEnter station prefix:")))|; (setq cp (getpoint "\nClick or specify center point : ")) );; and (progn (setq poly (vlax-ename->vla-object (ssname s 0)) e (fix (vlax-curve-getEndParam poly)) pos 0 par 0 acdist 0.0 lst nil cp (vlax-curve-getClosestPointToProjection poly cp '(0.0 0.0 1.0) ) ) ;; setq (while (/= par (1+ e)) (setq pt (vlax-curve-getPointAtParam poly par) pos (1+ pos) ) ;; setq (if (not parpt) (setq lst (cons (strcat ;|pre (itoa pos) "," "0.000,"|; "0.000," (rtos (caddr pt) 2 3) ) lst ) parpt pt ) ;; setq ;; the pdist variable is needed to the accumulated the distance (setq pdist (distance (list (car pt) (cadr pt)) (list (car parpt) (cadr parpt)) ) lst (cons (strcat ;|pre (itoa pos) "," (rtos (setq pdist (distance (list (car pt) (cadr pt)) (list (car parpt) (cadr parpt)))) 2 3) ","|; (rtos (setq acdist (+ acdist pdist)) 2 3) "," (rtos (caddr pt) 2 3) ) lst ) parpt pt ) ;; setq ) ;; if (if (equal pt cp 1e- (setq acdcp (- acdist)) ) (setq par (1+ par)) ) ;; while (if lst (progn (setq lst (mapcar '(lambda (x) (strcat (rtos (+ (atof x) acdcp) 2 3) (substr x (1+ (vl-string-search "," x))) ) ) (reverse lst) ) fo (open fn "w") ) ;; setq (foreach l lst (write-line l fo) ) ;; foreach (close fo) (startapp "notepad" fn) ;; added to open the new txt file ) ;; progn ) ;; if ) ;; progn ) ;; if (setvar 'osmode osm) (princ) ) ;; demo Regards, Marko Ribar, d.i.a. Quote Link to comment Share on other sites More sharing options...
highflybird Posted September 9, 2014 Share Posted September 9, 2014 prodromosm, try this revision... Regards, Marko Ribar, d.i.a. Good man! Quote Link to comment Share on other sites More sharing options...
Guest Posted September 9, 2014 Share Posted September 9, 2014 Thank you marko_ribar Quote Link to comment Share on other sites More sharing options...
