  • Replies 23
  • ROBP
    7
  • mdbdesign
    5
  • Sengna
    4
  • gazza_au
    3
Posted Images
I will be the first one:
Command: (LOAD "C:/ACAD ALL SUPPORT/DEVELOP/DEVELOP.LSP") C:DEV
Command: DEV
; error: quit / exit abort
Command:
Command: (vl-load-com)
Command: VLIDE
Command:
Command: DEV
Command:
Command:
Command: DEV
Folder added to search path.
Did I skip something beside bed time?
Command: DEV
Command:
Command: VLIDE
Command:
Command: DEV
Command:
Command:
Command: DEV
If that is where the lisp is located according to the tree,
Then in the lisp must read and be the following after the line
(defun C:DEV ()
(setq prgpath "C:/ACAD/ALL/SUPPORT/DEVELOP/")
Will try tonight, thank you.
