I use this lisp to insert blocks
I have two questions
A)
(defun c:textblock ()
(COMMAND "_layer" "_m" "text" "_c" "140" "" "")
(setq scl (getvar "useri1"))
(setq scl1 (* scl 1.5))
(setq dt1 (getpoint "\ninsert text block: "))
(command" "*insert" "textblock" dt1 scl1 scl1 "0" )
when the block insert to the drawing exlode but have a rotation
I am using tis Units : Decimal,meters ,grads,Direction north.
The drawing temlate and the block have the same settings in the units. I dont know why .
When iuse the same lisp without "*" i have no rotation problem but not exlope.
B) Second question
I have this lisp to insert a drawing stamp (Rtext)
(defun c:dstamp ()
(COMMAND "_layer" "_m" "dstamp" "_c" "140" "" "")
(setq dt1 (getpoint "\ninsert dstamp: "))
(command"insert" "dstamp" dt1 scl1 scl1 "0" )
I whant after insert to explode the Rtext 2 times to convert it to simple text
Thanks
Try
(defun c:textblock ( / DT1 SCL SCL1)
(command "insert" "*textblock" dt1 scl1 "0" )
(defun c:dstamp ( / DT1 SCL SCL1)
(command "insert" "*dstamp" dt1 scl1 "0"
 "_.explode" "_L"
 "_.explode" "_L")
HTH
Henrique
Thank you hmsilva
in the dstam (Rtex) explode only the 3rd line here is the dwg file i use
can you check it?
dstamp.dwg
You're welcome, prodromosm
(command "insert" "dstamp" dt1 scl1 scl1 "0")
(command "_.explode" "_L")
(initcommandversion)
(command "_.explode" "_P" "")
HTH
Henrique
Glad I could help!
Henrique
other variant.
Use Inserting Exploded Blocks
Preceding the name of the block with an asterisk (*) explodes the block and inserts the individual parts of it. The block definition is not added to the drawing
and QAFLAGS=5
does not depend on the amount of Rtext in the block.
(defun c:dstamp ( / DT1 SCL SCL1 SS *error* qf)
 (defun *error* ( msg )
   (and qf (setvar 'QAFLAGS qf))
       (princ (strcat "\n** Error: " msg " **")))
(mip:mark)
(command "_-insert" "*dstamp" dt1 scl1 scl1)
(if (setq SS (mip:get-last-ss))
     (setq qf (getvar 'QAFLAGS))
     (setvar 'QAFLAGS 5)
     (command "_.explode" ss "")
;;;* Mark data base to allow KB:catch.
;;;* http://www.theswamp.org/index.php?topic=15863.0
(defun mip:mark ( )
(if (setq *mip:mark (entlast)) nil
   (progn (entmake '((0 . "point") (10 0.0 0.0 0.0)))
      (setq *mip:mark (entlast))(entdel *mip:mark)))(princ))
;;;* returns selection set of entities since last mip:mark.
(defun mip:get-last-ss (/ ss tmp val)
 (setq val (getvar "cmdecho"))
 (setvar "cmdecho" 0)
 (if *mip:mark
   (progn (setq ss (ssadd))
          (while (setq *mip:mark (entnext *mip:mark))
            (ssadd *mip:mark ss)
          ) ;_ end of while
          (if (> (sslength ss) 0)
              (command "_.select" ss "")
              (setq tmp ss)
            ) ;_ end of progn
            (setq tmp nil)
          ) ;_ end of if
   ) ;_progn
   (alert
     "*mip:mark not set. \n run (mip:mark) before mip:get-last-ss."
   ) ;_ end of alert
 ) ;_if
 (setvar "cmdecho" val)
 tmp
) ;_ end of defun
Hi VVA,
nice code.
But, you'll need to explode twice, Rtext after explode becomes Mtext and you'll nead to explode again to become Text, as OP request.
You don't need to to change QAFLAGS SysVar to explode a selection set, if you just use the initcommandversion function before the explode command, will allow a selection set as an argument.
Henrique
