Unexplode?
Guest stargirl
Hi, i had a block in my drawings but then I exploded, i would like to know how can i make it like if i select it i select all the block?
is this reversible?
Type/ WBLOCK and make a block.
P.S.> use LAYER 0 for your block.
Guest stargirl
Thank you for your help! i posted in another board and they said it wasnt possible. I tried it and IT IS!!!
THANKS A LOT!!! :lol:
How about UNDO. Unless you have closed the ACAD session.
Hi, i had a block in my drawings ...
If you have the same block in another dwg you can bring a copy of it to your dwg. Or if you didn't purge dwg, find out the name of the block and insert it again. Try also to open bak file or autosave file to get your block.
Guest vizwhiz
Stargirl,
one Thing you might want to consider soon
is creating a directory and making a Library
for separate Blocks
and/or creating a "master" dwg file That has a LOT of commonly used Blocks
This way if you insert 1 "master block dwg file" ALL of your Blocks
That are within that dwg - will be automatically created in the dwg
That you are inserting into
This is similar to what TevsR was saying
in previous versions of Autocad when you created a Block it would dissapear
and Then you would have to use the command "oops" to undo It again (no bs)
now you have more options using the Dialog boxes when creating it
which version of Autocad are you using? This would help us help you
just an Idea
  • 7 years later...
I need reset the all drawings in scale;so wblock is not ---
Would you like to finish the question cadamrao? What are you trying to accomplish?
I'm kind of worried about him.... if he keeled over he still had time to type "---". :?
or maybe it's for dramatic effect... stay tuned!
