RESPNJR Posted May 9, 2014 Posted May 9, 2014 I am working on plumbing plans and i need to find the total length of pipes. I found this lisp routine (below) and it works fine the only problem is it displays the results in decimal units and i would like feet and inches. it would me nice if it would display the total lengths in the same units as the drawings. can you help. Thanks. (princ "\nTotalADDition v.1.0 activated! -run \"TADD\" to start or \"TADD-r\" to end." ) (defun c:tadd (/ itemarea itemperimeter itemlinelength itemarclength itemsplinelength itemregionperimeter itemcircumference itemsplineperimeter itemplineperimeter itemplinelength itemtracelength itemarclength itemellipselength a b c d p1 p2 itemlength tarea tperim tlength ) (vl-load-com) (defun *oo_object_modification* (objreactor objectsmodified) (setq selected_objects (vla-get-pickfirstselectionset (vla-get-activedocument (vlax-get-acad-object)) ) ) (setq itemarea 0 itemperimeter 0 itemlinelength 0 itemarclength 0 itemsplinelength 0 itemregionperimeter 0 itemcircumference 0 itemsplineperimeter 0 itemplineperimeter 0 itemplinelength 0 itemtracelength 0 itemarclength 0 itemellipselength 0 ) ;AREA (vlax-for n selected_objects (if (vlax-property-available-p n 'area) (if (eq (vla-get-objectname n) "AcDbRegion") (setq itemarea (+ itemarea (vla-get-area n))) (if (vlax-curve-isclosed n) (setq itemarea (+ itemarea (vla-get-area n))) ) ) ) ;;CIRCLE (if (vlax-property-available-p n 'circumference) (setq itemcircumference (+ itemcircumference (vla-get-circumference n))) ) ;;SPLINE (if (eq (vla-get-objectname n) "AcDbSpline") (if (vlax-curve-isclosed n) (setq itemsplineperimeter (+ itemsplineperimeter (vlax-curve-getdistatparam n (vlax-curve-getendparam n)) ) ) (setq itemsplinelength (+ itemsplinelength (vlax-curve-getdistatparam n (vlax-curve-getendparam n)) ) ) ) ) ;;REGION (if (eq (vla-get-objectname n) "AcDbRegion") (setq itemregionperimeter (+ itemregionperimeter (vla-get-perimeter n))) ) ;;PLINE (if (or (eq (vla-get-objectname n) "AcDb2dPolyline") (eq (vla-get-objectname n) "AcDbPolyline") ) (if (vlax-curve-isclosed n) (setq itemplineperimeter (+ itemplineperimeter (vlax-curve-getdistatparam n (vlax-curve-getendparam n)) ) ) (setq itemplinelength (+ itemplinelength (vlax-curve-getdistatparam n (vlax-curve-getendparam n)) ) ) ) ) ;;LINE (if (eq (vla-get-objectname n) "AcDbLine") (setq itemlinelength (+ itemlinelength (vla-get-length n))) ) ;;ARC (if (eq (vla-get-objectname n) "AcDbArc") (setq itemarclength (+ itemarclength (vla-get-arclength n))) ) (if (eq (vla-get-objectname n) "AcDbEllipse") (setq itemellipselength (+ itemellipselength (vlax-curve-getdistatparam n (vlax-curve-getendparam n)) ) ) ) ;;TRACE (if (eq (vla-get-objectname n) "AcDbTrace") (progn (setq plist (vlax-safearray->list (vlax-variant-value (vla-get-coordinates n)) ) ) (setq a (list (nth 0 plist) (nth 1 plist) (nth 2 plist))) (setq b (list (nth 3 plist) (nth 4 plist) (nth 5 plist))) (setq c (list (nth 6 plist) (nth 7 plist) (nth 8 plist))) (setq d (list (nth 9 plist) (nth 10 plist) (nth 11 plist))) (setq p1 (polar a (angle a b) (/ (distance a b) 2.0))) (setq p2 (polar c (angle c d) (/ (distance c d) 2.0))) (setq itemtracelength (+ itemtracelength (distance p1 p2))) ) ) ) ;;_end vlax-for (setq itemperimeter (+ itemcircumference itemsplineperimeter itemregionperimeter itemplineperimeter ) ) (setq itemlength (+ itemplinelength itemsplinelength itemlinelength itemtracelength itemarclength itemellipselength) ) (setq tarea (rtos itemarea 2 ) (setq tperim (rtos itemperimeter 2 ) (setq tlength (rtos itemlength 2 ) (acet-ui-status (strcat "Toatl Area: " tarea "\n" "Total Perimeter: " tperim "\n" "Total Length: " tlength) ) ) ;;OBJECT SELECTION (if oo_object_modification (progn (vlr-remove oo_object_modification) (setq oo_object_modification nil) ) ) (setq oo_object_modification (vlr-miscellaneous-reactor nil '((:vlr-pickfirstmodified . *oo_object_modification*)) ) ) ;;Command ended (if oo_object_modification_action (progn (vlr-remove oo_object_modification_action) (setq oo_object_modification_action nil) ) ) (setq oo_object_modification_action (vlr-command-reactor nil '((:vlr-commandended . *oo_object_modification*) ;(:vlr-commandcancelled . *oo_object_modification_CANCEL*)) ) ) ) ) (defun c:TADD-r () (if oo_object_modification_action (progn (vlr-remove oo_object_modification_action) (setq oo_object_modification_action nil) ) ) (if oo_object_modification (progn (vlr-remove oo_object_modification) (setq oo_object_modification nil) ) ) ) Quote
ReMark Posted May 9, 2014 Posted May 9, 2014 Extract the information to a format that can be placed in Excel, add the necessary formula for converting decimal inches to feet/inches and let the spreadsheet do the work. Quote
ymg3 Posted May 9, 2014 Posted May 9, 2014 Change these: (setq tarea (rtos itemarea 2 ) (setq tperim (rtos itemperimeter 2 ) (setq tlength (rtos itemlength 2 ) to: (setq tarea (rtos itemarea)) (setq tperim (rtos itemperimeter)) (setq tlength (rtos itemlength)) From Autocad Help: The mode and precision arguments correspond to the system variables LUNITS and LUPREC. If you omit the arguments, rtos uses the current settings of LUNITS and LUPREC. ymg P.S. Do edit your post to include code tags around your code Quote
Waheed Posted February 4, 2023 Posted February 4, 2023 please solve above and update need squared feet area on display bar regards (setq tarea (rtos itemarea)) (setq tperim (rtos itemperimeter)) (setq tlength (rtos itemlength)) Quote
