Hi
i use lots of predefined global variables that control the program flow. i wonder how autolisp reffer the variable and function with the same name?
(setq
  REBARLOWERDIA
  "3£16" ;_REBAR UPPER DIAMETER
(defun c:REBARLOWERDIA ()
 (setq	REBARLOWERDIA
 (getString (strcat "Set rebar diameter and frequncy ["
		    REBARLOWERDIA
is should be like this?
Thanks
Shay
A good programming practice will be to use asterisks to build global variable names to easily distinguish them:
(setq [color=blue]*[/color]REBARLOWERDIA[color=blue]*[/color]
thanx
In a nutshell, if you try to use the same symbol name for a function and a global variable it won't work (CAVEAT - that comment is in the context of the drawing document namespace, which is what you are referring to).
The symbol will contain whatever you last set it as, eg. a string, a real, an integer, or a function. It can't be two things simultaneously.
If you are experiencing ANY confusion understanding this, perhaps you haven't realised that "C:REBARLOWERDIA" does NOT refer to the same symbol as "REBARLOWERDIA".
FWIW -
You may also find PRAGMA to be of interest.
Cheers
Does my code is writen correctly?
I'm not sure your question samifox, are you asking if you did that correctly?
It appears so....
If you were trying to see if autolisp DISTINGUISHES between "C:REBARLOWERDIA" and "REBARLOWERDIA", then as clint mentioned yes it does. They are two different atoms, if I understand correctly.
hi
im writing a function (like setVar()) , for my own global variable for easily updating them as needed.
my problem is to access the global variables without actually call them, this the code i manage to write so far,
thanks
Shay
(defun setValue	(var val)
 (if (= (type var) 'STR)
    (set var (getstring (strcat "Enter new value for ["var"]<"'existValue">")))
(setq
   *upperRebarTitle*	"3£12" ;_REBAR UPPER DIAMETER
) ;_ end of setq
(defun C:UPRREBARTLT ()
 (setValue "UPRREBARTLT" "3x20")
) ;_ end of defun
I will write it like this:
(defun setValue( var val / tmp1 tmp2 )
(if (not val)
  (or (setq tmp1 (eval (read var)))
      (setq tmp1 "3£12"))
  (set (read var)
       (if (/= (setq tmp2
                     (getstring (strcat "Enter new value for [" var "] <" tmp1 ">")))
        tmp2
        tmp1))
 (set (read var) val)
Call to set a value directly:
(setValue "*upperRebarTitle*" "3x20")
Call to set a value by user input :
(setValue "*upperRebarTitle*" nil)
If the variable wasn't initialized, as default value will use "3£12".
(if (not val)
      (setq tmp1 "3£12"))
  (set (read var)
       (if (/= (setq tmp2
        tmp2
        tmp1))
hi MSasu,
trying to understand how this magic was done,
this is the evaluation :
(set (read var) "3x20")
(set *upperRebarTitle* "3x20")
now if im using
(set var val)
without (read) i get error, why?
Maybe this will help you understand:
(setq var1  "VAR2"
     var2  "eggs")
(print var1)                 ;a string
(print (read var1))          ;a symbol
(print (eval (read var1)))   ;value stored in above symbol
(setq var1  "VAR2"
     var2  "eggs")
Thanks you very much Msasu
you help me understand the eval much better!
