Survey Figures vs Finish 2D Lines
Hello All,
I'm setting up styles in C3D 2014 to process field codes into plottable line work. I am familiar with Figure Styles and the Figure Prefix Library but am unsure of the line work these two entities produce. I know that survey figures are hard to edit. My goal is to create lines that civil designers, drafters and engineers can easily edit if needed.
Any insight would be appreciated!
As Always, Thanks,
rlshound
When i bring in a field book i use quick select and select all survey figures and explode them. They turn into 3d polylines, then i use quick select again to turn the 3d polylines into 2d polylines. Then i change all the 2d polylines elevations to zero. I use points for grading and surface creation so i don't need line work to have 3D elevations, plus having surveyed information with elevation poses a lot of issues and its not worth it. The process of converting survey figures to 2d polylines with no elevation really only takes a minute or two. That's the best option I've found.
Hello EMS_0525, Thanks for taking the time, this is what I needed to know, I'll give it a try and keep you posted. Thanks Again! rlshound
