Hello again all.
i have been using tangent constraint to constrain the ball in a ball bearing to the inner ring so as to be able to rotate the ring and balls when the outer ring is grounded. However I believe this is giving me a fixed connection and not allowing a rolling motion between the two.
Can anyone suggest an alternative that will give the desired result.
Many thanks Jake8090.
