Need help (error: bad argument type: 2D/3D point: nil)
The function worked few days ago I dont get it, help me pls
when i press enter all the way I get the
(defun dtr (alfa)
(* pi (/ alfa 180.0))
(defun duom ()
(setq p0 (getpoint "\n Pazymek pradzios taska:"))
(if (null p0) (setq p0 (list 150.0 150.0)))
(setq H (getdist "\n Ivesk auksti H :"))
(if (null H) (setq H 30))
(setq a (getdist "\n Ivesk ilgi a :"))
(if (null a) (setq a 18.6))
(setq b (getdist "\n Ivesk aukšti b :"))
(if (null b) (setq b 7.2))
(setq R (getdist "\n Ivesk ilgi R :"))
(if (null R) (setq R 18.6))
(setq L (getdist "\n Ivesk ilgi L :"))
(if (null L) (setq L 25))
(setq w (getdist "\n Ivesk linijos stori W :"))
(if (null w) (setq w 0.5))
(defun koord ()
(setq p1 (polar p0 (dtr 90) H))
(setq p2 (polar p1 0 (- L a)))
(setq P7 (polar p2 (dtr 0) a))
(setq P3 (polar p7 (dtr 270) b))
;(setq p4 (polar P3 (dtr 270) R ))
;(setq p5 (polar P4 (dtr 180) R ))
(setq P6 (polar p5 (dtr 270) (- H (+ R b))))
(defun braiz ()
(command "PLINE" p0 "w" w "" p1 p2 p3 "ARC" "A" "-90" p5 "L" p6 p0 "")
(setq pl (entlast))
(command "hatch" "ansi31" 1 0 pl "")
(defun C:zzz()
(duom)
(koord)
(braiz)
The p5 don't have any value, is commented...
And then you are using p5 when setting p6
Henrique
I know the system don't need them it was the mistake before, but the system worked well without them, don't get it. Please don't look at p4 and p5 it's not the problem
(setq P6 (polar [color="red"][b]p5[/b][/color] (dtr 270) (- H (+ R b))))
HTH
Henrique
Changed the thing, but it shows the same error.
you'll need to set p4 and p5
(setq [color="red"][b]p5[/b][/color] (polar [color="red"][b]P4[/b][/color] (dtr 180) R ))
;; and
(command "PLINE" p0 "w" w "" p1 p2 p3 "ARC" "A" "-90" [color="red"][b]p5[/b][/color] "L" p6 p0 "")
Just uncomment p4 and p5, load the code and test it...
Henrique
Its the same error, I did what you say
On this side, tested without error...
I think Henrique is right, you must have a value for p5 variable since is used further in code. By un-commenting said lines, the routine works here, too.
If you tested again just the code from post #7, please pay attention that you just shifted the issue - here you were missing the value for p0 variable.
Please edit your previous posts and add the required code tags.
  • 7 years later...
Hi friends, i didnt want to open new topic, i have same problem. How we can get distance between 2 points which has different elevation.
Distance between this 2 point (1363.4 1467.25 5.3) (1386.27 1474.85 5.5)
(defun c:ucg()
(setq noks (ssget (list (cons 0 "point")))) ;just select the points
(setq len (sslength noks))
(setq counter 0)
(while (< counter len)
	(setq txt (ssname noks counter))
	(setq txtdata (entget txt))
	(setq kord1 (cdr (assoc 10 txtdata)))
 	(setq txt1 (ssname noks (+ counter 1)))
 	(setq txtdata1 (entget txt1))
 	(setq kord2 (cdr (assoc 10 txtdata1)))
	 (setq mes (distance kord1 kord2)) ; this line give error message
   (setq counter (+ counter 1))
  );end while
);end of program
@Mesut
Your lisp computes all distances but because mes keeps getting reset it will only have the distance of the last two points.
You can get dist from 3d points. your two points dist = 30.67
The error you getting is due to a bad while
lets say you have 3 points in your noks selection set
ssname noks 0
ssname noks 1
ssname noks 2
first pass counter = 0
dist noks 0 & noks 1
counter = 1
dist noks 1 & noks 2
counter = 2
dist noks 2 & noks 3 error because noks 3 doesn't exist
update while to
(while (< counter (- len 1))
                 or
(repeat (- len 1)
-edit-
(defun c:ucg (/ noks kord1 kord2 mes c len)
  (setq noks (ssget '((0 . "POINT"))))
  (if (<= (setq len (sslength noks)) 1)       ;need a minimum of two points
    (prompt "\nNot Enought Points Selected")
      (setq c 0)
      (repeat (- len 1)
        (setq txtdata (entget (ssname noks c))
              txtdata1 (entget (ssname noks (setq c (+ c 1))))
        (prompt (strcat "\nDistance : " (rtos mes 2))) ;don't know what your doing with mes but this will display it.
Edited by mhupp
  • Like 2
15 hours ago, mhupp said:
@Mesut
ssname noks 0
ssname noks 1
ssname noks 2
counter = 1
counter = 2
update while to
                 or
(repeat (- len 1)
-edit-
Thank you, I got it.
      (setq c 0)
      (repeat (- len 1)
