imax8v Posted May 14, 2014 Posted May 14, 2014 Hi everyone i wrote a script to draw 2 pLine and put dimension over them but i have problem with dim line offset. i dont understand effect of value given by command after picking start/end ponits of dimension. i've tried -1 or 0.5, but every time i load script place of dimension line is vary. my script is attached. thx for your help :smileywink: orthomode 0 osmode 0 pline 0,-1 w 0.03 0.03 6.894,-2.216 pline 6.894,-2.216 w 0.11 0.11 12.803,-3.257 _dimaligned 0,-1 6.894,-2.216 -0.2 (command) (command) _dimcontinue 12.803,-3.257 (command) (command) _dimaligned 0,-1 12.803,-3.257 -0.5 (command) (command) Quote
MSasu Posted May 14, 2014 Posted May 14, 2014 That query is for location of dimension line - by inputting a number, that means a displacement in the current direction of cursor, which may vary from a call to another. Please try to input a point instead. ... _dimaligned 0,-1 6.894,-2.216 [color=red][s]-0.2[/s] [/color]3.621, -0.623 ... Quote
imax8v Posted May 14, 2014 Author Posted May 14, 2014 thx dear MSasu that'll fix my problem, so i should rewrite my script Quote
