wannabe Posted December 5, 2008 Posted December 5, 2008 Anyone got a routine that can help me to produce a cross-section from a plan. Normally I make a polyline putting a little cross on each contour. I then use this to show my cross section contained within a grid showing height and and distance. I am aware this is possible in Map 3D, and dont expect a function for vanilla that can do this exactly the same. Nevertheless, if any improvements can be made to the current process it would be a big help . Thanks. Quote
Ritch7 Posted December 5, 2008 Posted December 5, 2008 i havent got a lisp for you im umfraid check the threads at the bottom, because im not a lisp man but im sure of what your'e asking isnt a hard task to say the least Quote
BOB'27T Posted December 5, 2008 Posted December 5, 2008 Check out this lisp that I use: QuickProfile[1].LSP Quote
wannabe Posted December 8, 2008 Author Posted December 8, 2008 Check out this lisp that I use: Hi Bob, Thats an excellent routine; thanks for the refferal. One small issue, and it really is minor, is that my contours are mainly on one layer, but there are a couple on another layer I need to add. I could easily do it manually, not a problem. But if there is a way of using this routine to enter multiple layers, then please let me know. Some drawings may allow me to convert all contours onto one layer. But that may mean copying xref's and things. So it would be good if I could ask this routine to recognise contours on multiple layers. Cheers. Quote
rupasinghe Posted October 3, 2009 Posted October 3, 2009 Hi Bob, Could you please explain how this QuickProfile LISP works? cheers Sanji Quote
afrazawan Posted February 26, 2012 Posted February 26, 2012 could u help me please how this LISP works? Quote
Lee Mac Posted February 26, 2012 Posted February 26, 2012 Would this help at all? http://www.cadtutor.net/forum/showthread.php?62153-data-from-contour&p=423779&viewfull=1#post423779 Quote
ReMark Posted February 26, 2012 Posted February 26, 2012 One would assume the lisp routine must somehow determine what contours are being crossed and their elevation then cut the appropriate section just like it would be done manually on the drafting board. Oops...looks like Lee Mac beat me to the punch here. Follow his advice. Quote
schoeller Posted September 19, 2013 Posted September 19, 2013 Sorry to bother, I wish to use quickprofile.lsp from Bricscad as a CAD-newby. This is what I did Drawing 3d polylines and/or splines on layer CONTOURS Drawing polyline on layer ALIGNMENT Loading script During execution defining contour layer as CONTOURS Select line from ALIGNMENT as horizontal Leaving exaggeration as default Hence I receive the error message ; ----- LISP : Call Stack ----- ; [0]...C:QP ; [1].....LISTPTINTERSECT ; ; ----- Error around expression ----- (VLAX-CURVE-GETDISTATPOINT HA-ENAME INTERSECTPT) Any hints for getting this to work are appreciated. Unfortunately I cannot read LISP code. I have attached the file I am working with. Best wishes from Bamako Sebastian quickprofile_test.dwg Quote
schoeller Posted September 22, 2013 Posted September 22, 2013 (edited) When doing in above sequence for step number Drawing 3d polyline I have to FLATTEN the polyline and then CONVERTPOLY to lwpolyline. Hence I get a profile drawn referenced to 0,0. Seems that 3d polyline is not read and 2d polyline neither. Unfortunately I loose the elevation information while doing so. Any hints appreciated Edited September 22, 2013 by schoeller Wrong information provided Quote
rahulcivilhzb Posted February 14, 2015 Posted February 14, 2015 Dear Friends, I want to know that how I make Typical Cross Section Drawing for Road Work & Culvert in Autocad , PLZ reply me early as possible. Quote
Organic Posted February 22, 2015 Posted February 22, 2015 If you are drawing a typical cross section then I would draw it as a polyline. Add some dimensions also afterwards. Quote
ReMark Posted February 22, 2015 Posted February 22, 2015 Dear Friends, I want to know that how I make Typical Cross Section Drawing for Road Work & Culvert in Autocad , PLZ reply me early as possible. Creating a cross-section using plain AutoCAD is pretty much like doing one manually on a drafting board unless you are working off of a 3D model. Are you? Quote
