hello,
I need help to select bloc by fence but i want to ignore attributes or just select blocks with base point on the fence.
So i've trying to add the dxf code (66.1) on this, but it doesn't work.
thank you for any help.
francoi-m
        (setq
         fence (listpol (ssname js (setq n (1- n))))
         js_ins (ssget "_F" fence '((0 . "INSERT")))
To ignore the attributed blocks .
(ssget '((0 . "INSERT") (-4 . "<NOT") (66 . 1) (-4 . "NOT>")))
Sorry i explain better
I want select all blocks by fence ( with or without attributes) but if the fence cross just an attribute, the block are not selected.
Thank you for answer.
As a kludge, could turn ATTDISP to Off prior to making the selection and reset the value after the selection. It will probably require a REGEN after setting ATTDISP to OFF
(setq om (getvar "ATTMODE"))
(setq "ATTMODE" 0)
(command "_.REGEN")
(while (not ss)
      (setq ss (ssget '((0 . "INSERT"))))
(setvar" ATTMODE" om)
(command "_.REGEN")
Very ugly. -David
@ David
Is not this enough ?
(while (setq ss (ssget '((0 . "INSERT")))))
The ssget function does not recognise the attributes in the block while selecting it , so the block object is the one that is considered in this case . ;)
I have some blocks composed by one point and two attributes on each vertex of many polyline. I wan't select all blocks who have the point on polyline by create a fence with polyline, and ignore blocks who just crossing the polyline by her attributes.
On my code when i use ssget function all blocks crossing the polyline was selected.
If you have an idea.
Maybe you should upload a sample DWG.
Try david's suggestion by turning off the attributes (attmode = 0) while you are running the codes then reset them back ( attmode = 1).
@ David
Depends if you want single or multiple loop of selections
Edited by David Bethel
Hi
i've test to put on my lisp but i've an error if you can look
(defun c:selbloc ( / js om js_all n fence ss nb)
 (princ "\nSélectionnez les polylignes: ")
 (setq js (ssget '((0 . "LWPOLYLINE"))) js_all (ssadd))
 (cond
   (js
     (repeat (setq n (sslength js))
        (setq "ATTMODE" 0)
         (command "_.REGEN")
   (while
     (not ss)
       (setq
         ss (ssget "_F" fence '((0 . "INSERT")))
       (cond
         (ss
           (repeat (setq nb (sslength ss))
             (ssadd (ssname ss (setq nb (1- nb))) js_all)
     (sssetfirst nil js_all)
(command "_.REGEN")
;;; listpol by Gille Chanteau ;
;;; Returns the vertices list of any type of polyline (WCS coordinates) ;
;;; Argument ;
;;; en, a polyline (ename or vla-object) ;
(defun listpol (en / i p l)
 (setq i
   (if (vlax-curve-IsClosed en)
     (vlax-curve-getEndParam en)
     (+ (vlax-curve-getEndParam en) 1)
 (while (setq p (vlax-curve-getPointAtParam en (setq i (1- i))))
   (setq l (cons (trans p 0 1 ) l))
Edited by francois-m
Try this ...
(defun c:Test (/ *error* om ss i sad s n)
 ;;    Tharwat 23.05.2014        ;;
 (defun *error* (msg)
   (if om
     (setvar "ATTMODE" om)
   (command "_.REGEN")
   (if (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")
     (princ msg)
     (princ (strcat "Error : < ** " msg " ** >"))
;;; Argument ;
   (setq i
     (setq l (cons (trans p 0 1) l))
 (if (setq ss (ssget '((0 . "LWPOLYLINE"))))
     (setq sad (ssadd)
     (setvar "ATTMODE" 0)
     (command "_.REGEN")
       (if (setq s (ssget "_F"
                          (listpol (ssname ss (setq i (1- i))))
                          '((0 . "INSERT"))
         (repeat (setq n (sslength s))
           (ssadd (ssname s (setq n (1- n))) sad)
     (command "_.REGEN")
 (sssetfirst nil sad)
)(vl-load-com)
thanks a lot.
it work verry fine. just for my information why have you force to create a defun error.
francois-m
thanks a lot.
You're welcome .
To reset the system variable "attmode" if any error took a place while running the codes .
