madriver Posted May 27, 2014 Posted May 27, 2014 I am getting a fatal error (Internal Error: !scandr.cpp@1117:@eLockViolation). I have run an audit, full purge and re-saved several times. An odd thing occurs. I will do a “saveas” and then close the file and it will ask me again if I want to “save changes” the file again. Any thoughts?... Quote
ReMark Posted May 27, 2014 Posted May 27, 2014 What program are you actually using? Are you working over a network? Is your program up-to-date with all service packs? Quote
madriver Posted May 27, 2014 Author Posted May 27, 2014 acad 2012, no, probably. Regardless, the fatal error ONLY occurs on a specific file. If I open another file the problem does not occur. It is probably in some lisp routine but I am not sure Quote
ReMark Posted May 27, 2014 Posted May 27, 2014 I've read that this might be the cause.... entmod is triggered from an opendcl form ...but I have no idea how to fix it. Sorry. Quote
madriver Posted May 27, 2014 Author Posted May 27, 2014 yes...did a recovery, purged, audit and re-named. I think it is linked to a bad lisp routine (I got the link from this site). But I am not positive, that or a bad custom hatch routine. Thanks for your help. Quote
ReMark Posted May 28, 2014 Posted May 28, 2014 Attach a copy of the drawing to your next post. Someone here will take a look at it. Quote
