hobkyl Posted May 28, 2014 Share Posted May 28, 2014 I am trying to add elevation tags to piping, and am able to however the text size is way too small to be legible for field use. I've tried to access properties for the block, editing object display, etc etc. How do I edit the text height for the block so that all elevation tags i put in the drawing come out as wanted? Thanks Quote Link to comment Share on other sites More sharing options...
hobkyl Posted May 30, 2014 Author Share Posted May 30, 2014 Anyone chime in? Quote Link to comment Share on other sites More sharing options...
hertz hound Posted May 30, 2014 Share Posted May 30, 2014 Find out what the block name is for the text. Go into the block editor and make sure the text Is non-annotative and 1" tall. If that does not work just build a new tag. Quote Link to comment Share on other sites More sharing options...
