I am attempting to draw an internal Archimedes' Screw in Inventor 2015.
Internal Screw.ipt
3D-Sketch --> Sweep --> Type=Path & Guide Rail --> Output=Surface --> Vertical line as profile
All OK
Cannot select construction line as Path.:unsure:
What have I done, or what am I doing, wrong?
Delete the 3D sketch.
Select the Coil command and set the output to Surface.
Select the Coil construction line as the axis.
Set the desired Height and Pitch (turns).
I would never ever use the 3D sketch helix - I don't understand why it even exists since it is difficult to fully constrain/edit.
