How does one write double quotes to a file?
for example:
(write-line "alpha beta alpha beta "delta" alpha beta alpha beta")
N.B. delta should have double quote marks, I need it all on one line so this discounts write-char (I think)?
Thanks for any help on this
Check out the 'Control Character in Quoted Strings' topic in the Vlisp help. It is actually a good one.
At least that's how it is listed in A2K help. -David
Following on the above replies, prefix a quote with a backslash to output it as a literal string
\"delta\" will output as "delta"
(write-line "alpha beta alpha beta \"delta \" alpha beta alpha beta")
Regards,
Jammie
As in Jammie's example above - the \ (backslash) character prefix will allow the subsequent character to be read as a string instead of a syntax.
i.e.
\n = new line
\t = tab
etc
And so, if you want to specify for example a filepath, one must include the double backslash to indicate a single:
C:\\Users\\Lee Mac\\Documents....
This may also be a way around another problem of spaces in directory names the path stops at a space using lisp, had to resort to VBA to get around it.
or
C:\\Users\\Lee\ Mac\\Documents....
