Jake8090 Posted June 1, 2014 Posted June 1, 2014 Could someone help with a little advice please. Having just about reached the end of my first project, I have two assembly files which were used as experimental trial files. Now I am happy with the completed results I would like to delete these files. Will deleting also delete component files used. Could I take this opportunity to thank those who have helped me along the the way. Jake8090 Quote
JD Mather Posted June 1, 2014 Posted June 1, 2014 Deleting one file will not delete another file. Quote
Lazer Posted June 4, 2014 Posted June 4, 2014 If you are unsure you could copy the models to another folder then if the worst was to happen you can always go back. In this case it should be ok. You also have an old versions folder that can be a life saver if all goes wrong. Quote
