kiticel Posted June 3, 2014 Posted June 3, 2014 Hi, I am having trouble all of a sudden when I am in paperspace and am working in a viewport. When I select a line that belongs on a layer, it does not tell me which layer it is on. It just stays on the current layer. Any line i choose, the layer info just stays on whatever is set to current. This makes it impossible to freeze layers in that current viewport. Any help on this would be greatly appreciated!!! Quote
Tiger Posted June 4, 2014 Posted June 4, 2014 HI and welcome to the forum! Would the command LAYFRZ help? Then you can click on a line and the lines layer is then frozen. Also the command LAYMCUR switches to the layer of the object you click on. Are you sure that the lines are not in fact on the current layer? Quote
Dana W Posted June 4, 2014 Posted June 4, 2014 Have you made the viewport "CURRENT"? You have to be in modelspace through the viewport. Quote
Dana W Posted June 4, 2014 Posted June 4, 2014 Change PICKFIRST to 1.Bingo. Bazzinga. Huzzah, alle looya. (that last one reminds me of a babe I used to date.) Quote
