Trebuchet Posted June 4, 2014 Posted June 4, 2014 Has anyone had this problem before? See attached picture. Switching from model space to paperspace, one of my viewports will get stuck on the screen from it's position when it appears. Then, it won't leave, no matter how many times I regen. I can switch paperspace tabs, and even go back to model space and it will still be there. The only way I've found to get rid of the ghost image is to change my layer state, or go into and then back out of the block editor. Quote
RobDraw Posted June 4, 2014 Posted June 4, 2014 Sounds like a hardware problem. Update graphics driver. If that doesn't solve it, upgrade. Quote
Trebuchet Posted June 4, 2014 Author Posted June 4, 2014 Ya, I'll try that. Forgot to say it happens in pretty much all of my drawings. Quote
ReMark Posted June 4, 2014 Posted June 4, 2014 What are the computer specs? Dedicated graphics card or onboard graphics chip? Is hardware acceleration enabled? Quote
mdbdesign Posted June 4, 2014 Posted June 4, 2014 (edited) Do you have any field in this drawing? Just update my graphic driver and all my drawing with field (scale) still show ghost viewport. When explode or delete field it back to normal. I think it happen only in paper space. What is causing this: I don't know. Edited June 4, 2014 by mdbdesign Update driver Quote
