Hello guys :)
This is my first post here and hope all guys here doing well .
I need a lisp routine than can copy a closed polyline or circle from blocks to active space ( Model ) .
Any one can help me please ?
Thanks in advance .
EDIT : I need to use ssget function to be able to select many blocks please .
Edited by Coder
Welcome to CADTutor. :)
I can't help you with writing the lisp, but if you are not aware of it,
there is an Express Tool called Nested Copy, which I love, and essentially does what
you are trying to do.
Thank you Daggad :)
I know the command but I need to use multiple selection set because i have many blocks to go with .
So you've got nested blocks in your drawing, and you're wanting to be able to select multiple nested closed polylines/circles from within those nested blocks, and then have a routine copy all of the selected items into modelspace, perhaps placing them on the clipboard or at the origin (0,0,0)?
Thanks for you answer Bhull :)
Lee routine is with single selection , and I need to be able to select many blocks .
I upload a sample block and I need to copy the circle in RED color and the Polyline rectangle in YELLOW in the same location as the original blocks are .
Many thanks
Fan.dwg
Oh I see- well after a quick search and looking in a place or two, it seems as if what you're requesting is a bit above my coding capabilities- selecting multiple nested entities has even given such gurus as Lee Mac and Tharwat troubles, as is seen in this thread:
http://www.cadtutor.net/forum/showthread.php?86573-Selection-set-with-multiple-nested-objects
That's not to say they can't do it- that's just saying that I cannot do it. Sorry about that, but perhaps this insight will be of assistance anyways.
Thank you Bhull for your time and help , that is the same also . :(
