MJLM Posted June 9, 2014 Posted June 9, 2014 The idea is to store some global variables of some lisp routines in a drawing file so that when I load this drawing again these values are reloaded into session memory. I found the vlax-ldata-put & vlax-ldata-get commands but these work with a specific entity or am I wrong? I find it restrictive and inappropriate to having selecting an entity to store values. What would be the best way to do that? Quote
Tharwat Posted June 9, 2014 Posted June 9, 2014 Hi , You can export the variable to a txt file and save it in the support folder or anywhere you 'd like and after that you can call that file by its name with its contents , or you can create dictionary which would increase the size of your drawing if you have many values to save with in many dictionaries . It is up to you . Quote
Bhull1985 Posted June 9, 2014 Posted June 9, 2014 You can also try the (vl-bb-set) and (vl-bb-ref) methods , there are plenty of documentation on those two, and they're really easy to use. Which, FYI, stands for visual lisp, blackboard, set/ref. Would have to check the documentation to determine where these values are stored, unless someone knows it off the top of their head. Quote
MJLM Posted June 9, 2014 Author Posted June 9, 2014 (edited) Thanks both of you. It seems the method bhull proposed is quite fast and flexible. Edit: it seems that the (vl-bb-set) and (vl-bb-ref) work only during one autocad session and not per drawing file. Whatever file I open the same values I get loaded and only for one session. I will have to look deeper on this. Edited June 9, 2014 by MJLM Quote
Snownut Posted June 9, 2014 Posted June 9, 2014 Problem with BB variables is they are lost when you close the drawing, I would suggest learning about creating a custom dictionary in each drawing. If you are saving simple values it will not increase drawing size by much. The issue with external text files is you will need to do a lot of coding to make sure all variables are changed if you do an undo command etc. (I tried that route not very nice). Also if you save the values right in the drawing within a dictionary you will not need to save the text file with the drawing file, especially if you want to send them to someone. I save approx 100 variable values within a custom dictionary with no issues, you will also need to learn the proper DXF codes to save your values to whether they be text, integer, reals point values etc. once you have things figured out it is very safe and reliable mothed of saving the values. Additionally if you undo the lisp function that created or set the variable values, the values will revert back automatically. (just as an undo should). Quote
Bhull1985 Posted June 10, 2014 Posted June 10, 2014 The idea is to store some global variables of some lisp routines in a drawing file so that when I load this drawing again these values are reloaded into session memory. Yeah, that's my bad. Hadn't tested the vl-bb-set/ref commands more thoroughly I would have known they're just for the current session. Seems like snownuts method would be the best way to accomplish what you're asking. Personally I would create a toolbar button and macro to access your dictionary, that way you can 1-click and then edit with whichever information you're adding. Toolbar button or lisp routine, just something to make accessing and modifying the dictionary easy. Perhaps snownut would help with this....although I'm sure we could find something working, that requires research and time...that I don't have atm Quote
Snownut Posted June 10, 2014 Posted June 10, 2014 Below is the code I use, there are several functions and sub-functions all included; 1.-Create New Dictionary 2.-Create new xrecord within the created dictionary 3.-Append an xrecord 4.-Read an xrecord 5.-Update an xrecord I had a little assistance from Lee Mac on these functions, they work flawlessly in ACAD 2004 and up to at least 2011, and Bricscad 12 through current version. ;============================= Begin < GM_Dict > Function =====================================; ; Function to Create the "SADATA_DICT" within the NOD ; ; Syntax for function call; ; ; (GC_Dict < dictname >) ; ; Example - (GC_Dict "SADATA_DICT") ; ; Created by B. Fillmore ; (defun GC_Dict ( dictname / adict) (if (not (setq adict (dictsearch (namedobjdict) dictname))) (progn (setq adict (entmakex '((0 . "DICTIONARY")(100 . "AcDbDictionary")))) (if adict (setq adict (dictadd (namedobjdict) dictname adict))) ) (setq adict (cdr (assoc -1 adict))) ) );defun ;(GC_Dict "SADATA_DICT") Calling Line ; ; ; ;============================== End < GM_Dict > Function ======================================; ;=========================== Begin < GM_Xrecord > Function ====================================; ; Function to Create an XRECORD in the "SADATA_DICT" within the NOD ; ; Syntax for function call; ; ; (GM_Xrecord < XRECORD NAME >) ; ; Example - (GM_Xrecord "LDATA_VARS") ; ; Created by B. Fillmore ; (defun GM_Xrecord ( DATA_VARS / adict anXrec) (cond ( (setq adict (GC_Dict "SADATA_DICT")) ; "SADATA_DICT" is the name of the dictionary (cond ( (not (setq anXrec (dictsearch adict DATA_VARS)) ) (setq anXrec (entmakex values)) (if anXrec (setq anXrec (dictadd adict DATA_VARS anXrec)) );if );not (setq anXrec (cdr (assoc -1 (dictsearch adict DATA_VARS))) );setq );cond );setq );cond );defun ;(GM_Xrecord "EDATA_VARS") Calling Line (setq DATA_VARS "EDATA_VARS") ; ; ; ;============================ End < GM_Xrecord > Function =====================================; ;=========================== Begin < Append_Xrecord > Function ===============================; ; Function to add values to an existing XRECORD using the DXF Group Code ; ; Syntax for function call; ; ; (Append_Xrecord <XRECORD NAME> <DXF Group Code to Update> <Value to store>) ; ; Example - (Append_Xrecord "EDATA_VARS" 45 0.0) ; ; ; ; Returns all associations of a key in an association list ; ; Created by B. Fillmore ; (defun Append_Xrecord (DATA_VARS DXF_VAL NEW_VAL / SAdict anXrec xRecFile) (setq DATA_VARS (strcat tabname DATA_VARS) SAdict (GC_Dict "SADATA_DICT") anXrec (dictsearch SAdict DATA_VARS) ) (if (= (assoc DXF_VAL anXrec)nil) (progn (setq values (append anXrec (list(cons DXF_VAL NEW_VAL)) ) ) (entdel (cdr (assoc -1 anXrec))) (GM_Xrecord DATA_VARS) ) ) );defun ;(Append_Xrecord "EDATA_VARS" 46 0.0) Calling Line (setq DATA_VARS "EDATA_VARS") ; ; ; ;========================== End < Append_Xrecord > Function ===================================; ;=========================== Begin < GetVar_Xrecord > Function ===============================; ; Function to retrieve values from an XRECORD using the DXF Group Code ; ; Syntax for function call; ; ; (GetVar_Xrecord <XRECORD NAME> <DXF Group Code to Update> <Nth Group Code>) ; ; Example - (GetVar_Xrecord "LDATA_VARS" 300 2) ; ; ; ; LM:mAssoc - By; Lee Mac ; ; Returns all associations of a key in an association list ; ; Created by B. Fillmore ; (defun GetVar_Xrecord ( DATA_VARS DXF_VAL LnmBr / xRecFile vars ) (defun LM:mAssoc ( DXF_VAL xRecFile / item ) (if (setq item (assoc DXF_VAL xRecFile)) (cons (cdr item) (LM:mAssoc DXF_VAL (cdr (member item xRecFile)))) ) );defun (if (/= DATA_VARS "ODATA_VARS") ; "ODATA_VARS is a set of DXF codes within the dictionary (setq DATA_VARS (strcat tabname DATA_VARS)) ) (setq vars (GM_Xrecord DATA_VARS)) (cond (vars (setq xRecFile (entget vars)) (cdr (cons DXF_VAL(nth LnmBr (LM:mAssoc DXF_VAL xRecFile)))) ) (T nil) ) );defun ;(setq VARNAME (GetVar_Xrecord "LDATA_VARS" 300 2)) Calling Line ; ; ; ;========================== End < GetVar_Xrecord > Function ===================================; ;========================== Begin < Update_Xrecord > Function =================================; ; Function to Update the values in an XRECORD using the nth DXF Group Code ; ; Syntax for function call; ; ; (Update_Xrecord <XRECORD NAME> <DXF Group Code to Update> <New Value> <Nth Group Code>) ; ; Example - (Update_Xrecord "LDATA_VARS" 300 "Update test successful!" 3 ) ; ; ; ; LM:mAssoc - By; Lee Mac ; ; Returns all associations of a key in an association list ; ; Created by B. Fillmore ; (defun Update_Xrecord (DATA_VARS DXF_VAL MOD_VAL LnmBr / xRecFile Values SAdict) (defun LM:mAssoc ( DXF_VAL xRecFile / item ) (if (setq item (assoc DXF_VAL xRecFile)) (cons (cdr item) (LM:mAssoc DXF_VAL (cdr (member item xRecFile)))) ) );defun (if (/= DATA_VARS "ODATA_VARS") (setq DATA_VARS (strcat tabname DATA_VARS)) ) (setq SAdict (dictsearch (namedobjdict) "SADATA_DICT") xRecFile (dictsearch (cdr (assoc -1 SAdict)) DATA_VARS) ) (setq values (subst (cons DXF_VAL MOD_VAL) (cons DXF_VAL (nth LnmBr (LM:mAssoc DXF_VAL xRecFile))) xRecFile) ) (entdel (cdr (assoc -1 xRecFile))) (GM_Xrecord DATA_VARS) );defun ; (setq DATA_VARS "LDATA_VARS") ;(Update_Xrecord "LDATA_VARS" 300 "Nmbr" 2) Calling line ; ; ; ;========================== End < Update XRecord > Function ===================================; ;============================ Begin < New_Xrecord > Function ==================================; ; Function to Create an XRECORD with Default Values ; ; Syntax for function call; ; ; (New_Xrecord <XRECORD NAME> ) ; ; Example - (Update_Xrecord "LDATA_VARS") ; ; Created by B. Fillmore ; ; ; (defun New_xRecord ( DATA_VARS / Values vars) (if (/= DATA_VARS "EDATA_VARS" DATA_VARS "HDATA_VARS" DATA_VARS "LDATA_VARS" DATA_VARS "ODATA_VARS") (progn (alert "There are no xRecord Values to Create xRecord for ! \nYou must enter the Values Reference to proceed !") (exit) );progn );if (if (= DATA_VARS "EDATA_VARS" ) (setq DATA_VARS (strcat tabname DATA_VARS) Values (list(cons 0 "XRECORD" ) ; used for EDA Data File Defaults in "XRECORDS" (cons 100 "AcDbXrecord" ) (cons 3 "0" ) (cons 40 0.0 ) (cons 41 0.0 ) (cons 42 0.0 ) (cons 43 0.0 ) (cons 44 0.0 ) (cons 45 0.0 ) (cons 46 0.0 ) (cons 47 0.0 ) (cons 70 0 ) (cons 71 0 ) (cons 72 0 ) (cons 73 0 ) (cons 74 0 ) (cons 75 0 ) (cons 76 0 ) (cons 77 0 ) (cons 78 0 ) (cons 79 0 ) (cons 270 0 ) (cons 271 0 ) (cons 272 0 ) (cons 273 0 ) (cons 300 "0" ) (cons 301 "0" ) ) );setq );if ;(setq DATA_VARS "EDATA_VARS") ;(New_Xrecord "EDATA_VARS") (if (= DATA_VARS "HDATA_VARS" ) (setq DATA_VARS (strcat tabname DATA_VARS) Values (list(cons 0 "XRECORD" ) ; used for House Data File in "XRECORDS" (cons 100 "AcDbXrecord" ) (cons 40 0.0 ) (cons 41 0.0 ) (cons 70 0 ) (cons 71 36 ) (cons 72 10 ) (cons 270 1 ) (cons 271 0 ) (cons 272 0 ) (cons 273 0 ) (cons 300 "Drain Outlet" ) ) );setq );if ;(entmakex values) ;(setq DATA_VARS "HDATA_VARS") (if (= DATA_VARS "LDATA_VARS" ) (setq DATA_VARS (strcat tabname DATA_VARS) Values (list(cons 0 "XRECORD" ) ; used for Lot Data File in "XRECORDS" (cons 100 "AcDbXrecord" ) (cons 3 "Septic Assistant") (cons 70 0 ) (cons 71 0 ) (cons 300 "Town" ) (cons 300 "County" ) (cons 300 "Book" ) (cons 300 "Page" ) (cons 300 "N/A" ) (cons 300 "Lot" ) (cons 300 "Map" ) (cons 300 "Area" ) (cons 300 "Block" ) (cons 300 "Unit" ) (cons 301 "Prev CA " ) (cons 301 "CA2012..." ) (cons 301 "Yes" ) (cons 302 "No" ) (cons 303 "No" ) (cons 304 "No" ) ) );setq );if ;(setq DATA_VARS "LDATA_VARS") ; (New_Xrecord "LDATA_VARS") (if (= DATA_VARS "ODATA_VARS" ) (setq Values (list(cons 0 "XRECORD") ; used for Lot Owner File in "XRECORDS" (cons 100 "AcDbXrecord") (cons 3 "Septic Assistant") (cons 300 "O-Name" ) (cons 300 "O-Street" ) (cons 300 "O-State" ) (cons 300 "O-Town" ) (cons 300 "O-Zip" ) (cons 300 "O-Phone" ) (cons 300 "O-Email" ) (cons 301 "A-Name" ) (cons 301 "A-Street" ) (cons 301 "A-Town" ) (cons 301 "A-State" ) (cons 301 "A-Zip" ) (cons 301 "A-Phone" ) (cons 301 "A-Email" ) (cons 302 "Site Street" ) (cons 302 "Sub-Name" ) (cons 302 "SA2012..." ) ) );setq );if (if (= (GM_Xrecord DATA_VARS) nil) (progn (Alert (strcat "\nThe xRecord < " DATA_VARS " > was not Created" "\n" "\nThe likely cause, there where no <Values> variables") ) (exit) ) );if T );defun ;(New_Xrecord "EDATA_VARS") Example Calling line ; ; ; ;============================ End < New XRecord > Function ====================================; Quote
BIGAL Posted June 11, 2014 Posted June 11, 2014 These are limited and may be altered by 3rd part software but may be usefull Useri1 ... Useri5 5 integers Users1... Users5 5 strings Userr1 ... Userr5 5 reals personally like above I would now use Xdata Quote
MJLM Posted June 11, 2014 Author Posted June 11, 2014 (edited) Below is the code I use, there are several functions and sub-functions all included; 1.-Create New Dictionary 2.-Create new xrecord within the created dictionary 3.-Append an xrecord 4.-Read an xrecord 5.-Update an xrecord I ve found something similar in the afralisp website. I tried your code too. However both of them, although I made no changes, give me nil when I execute the (Append_Xrecord "EDATA_VARS" 45 0.0) command. I have run first on a new drawing the (GM_Xrecord "EDATA_VARS") function. Any ideas? Edited June 11, 2014 by MJLM Quote
MJLM Posted June 11, 2014 Author Posted June 11, 2014 (edited) personally like above I would now use Xdata yeah but to my knowledge Xdata are always attached to an entity. That I don't find practical for global parameters/settings. Edited June 11, 2014 by MJLM Quote
Snownut Posted June 11, 2014 Posted June 11, 2014 You need to run the new xrecord function 1st. Quote
BIGAL Posted June 12, 2014 Posted June 12, 2014 (edited) MJLM I created Xdata no probs that was not attached to any entity using it to store current variables rather than Setvar USER?? also allowed lots more variables. Can post example if you want but it is similar to Snownut version just written a bit different. Edited June 12, 2014 by BIGAL Quote
MJLM Posted June 12, 2014 Author Posted June 12, 2014 Ok I may have understood something else. I was actually thinking the associate dxf code -3 of an entity as xdata. Quote
