Jake8090 Posted June 10, 2014 Posted June 10, 2014 Good morning all, here we are again. Trying to cut slot in a shaft for a woodruff key. Been trying a while now without success. There must be a way, looked on youtube but nothing there. can anyone help. I am sure this must have been done many times by more experienced user's in inventor. Jake8090 Quote
JD Mather Posted June 10, 2014 Posted June 10, 2014 Extrude - Cut. Attach your file here and end all doubt. Quote
Jake8090 Posted June 10, 2014 Author Posted June 10, 2014 Thanks JD, Having problems loading files. However I am ok putting the slot in the shaft using extrude, The problem is getting the curve radius of the woodruff key to the bottom face of the slot. Jake8090 Quote
JD Mather Posted June 10, 2014 Posted June 10, 2014 I can't help but think I must be missing something? See attached file. Shaft Keyways.ipt Quote
Jake8090 Posted June 11, 2014 Author Posted June 11, 2014 Got it JD,Thanks for your patience. This also answer's my previous thread although I achieved results with the the face command. Never occurred to me to extrude each side of the vertical plane. Jake8090 Quote
