dan_g8 Posted June 12, 2014 Posted June 12, 2014 Hi Im new to lsp, i have a text file that has been generated from an external source, i need to import the data into cad within a table. The text file has been written with spaces splitting the cell values. for example The text file would read: CADTutor The best free help for AutoCAD on the web The table would need to be as follows: Column A..|Column B........... | Column C CADTutor |The best free help| For AutoCAD on the web Could anyone point me in the right direction of how to do this, I hope this makes sence?! Dan Quote
fixo Posted June 12, 2014 Posted June 12, 2014 Found this one on my machine, give it a try (use tab delimited file as source) (defun C:TX2TB (/ atable c delim file headers i lst p pt r th wids x) ;; fixo 2008 (excerpt from old lib. utils) ;; local defuns (defun file-to-list (filename / file result line) (if (findfile filename) (progn (setq file (open filename "r")) (while (setq line (read-line file)) (setq result (cons line result)) ) (close file) (reverse result) ) (alert (strcat "File " filename " not found!")) ) ) (defun split-string (str delim / pos) ;; Splits a string into a list of strings at every ;; occurrence of the delimiter (single-letter string). (setq pos (vl-string-position (ascii delim) str)) (if (null pos) (list str) (cons (substr str 1 pos) (split-string (substr str (+ pos 2)) delim) ) ) ) (defun setcelltext (col row st aln) (vla-settext atable row col st) (vla-setcellalignment atable row col aln) ) ;; main part (setq file (getfiled "Select points file:" "C:\\Test\\" "TXT;CSV" ) ;; text file is tab delimited, values are in order of: a[TAB]b[TAB]c[TAB]d etc. (setq lst (file-to-list file)) (setq delim (chr 9));TAB ;(setq delim (chr 59));semicolon ;(setq delim (chr 44));comma (setq lst (mapcar '(lambda (p)(split-string p (chr 9)))lst));used TAB delimiter (setq i 0) ;(setq headers nil) (repeat (length (car lst)) (setq headers (cons (strcat "Column" (itoa (setq i (1+ i)))) headers))) (setq headers (reverse headers)) (setq th (if (zerop (getvar 'textsize))(* (getvar 'dimtxt) 1.5)(* (getvar 'textsize) 1.5))) (repeat (length headers) (setq wids (cons (apply 'max (mapcar '(lambda(y)(* (strlen y) th)) (mapcar 'car lst))) wids) ) ) (if (setq pt (getpoint "\n Specify Table Location :")) (progn (setq atable (vla-addtable (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)) ) ) (vlax-3d-point pt) (+ (length lst) 2) (length headers) th (* th 15) ) ) (setq i -1) (repeat (length (car lst)) (vla-setcolumnwidth atable (setq i (1+ i)) (nth i wids)) ) ;;title (vla-settext atable 0 0 (strcat "Table Title") ) ;headers (setq c -1 r 1) (repeat (length (car lst)) (setcelltext (setq c (1+ c)) r (nth i headers) 5);align middle center ) (setq r 2) ;; data rows (foreach item lst (setq c 0) (foreach a item (setcelltext c r a 4);align middle left (setq c (1+ c))) (setq r (1+ r))) ) ) (princ) ) (vl-load-com) Quote
BIGAL Posted June 13, 2014 Posted June 13, 2014 Just a couple of extra to Fixo's above maybe usefull those not familar with chr x either can be used in most cases but Tab requires chr. Next step once the rules are known is to create a table (setq delim (chr 9));TAB ;(setq delim (chr 59));semicolon ;(setq delim (chr 44));comma ;(setq delim ",") ; comma ;(setq delim " ") ; space ;(setq delim (chr 32)); space ;(setq delim (chr 46)); period ;(setq delim ".")); period ;(setq delim (chr 45)); - minus ;(setq delim "-)); - minus Just a question is the data a column of letters always the same lengths for each word then different method can do it using SUBSTR (setq ans (substr textstring 1 9)) ; this is Cadtutor Quote
dan_g8 Posted June 13, 2014 Author Posted June 13, 2014 (edited) thanks for the reply guys that's perfect. The data is arranged into columns so the characters 1-9 need to go to column a characters 10-25 in column b etc. where abouts would the (setq ans (substr textstring 1 9)) need to go? also is it possible to change the column width for each column individually? ive worked out how to do all of them but for example column b needs to be about double the size of a? Edited June 13, 2014 by dan_g8 Quote
BIGAL Posted June 14, 2014 Posted June 14, 2014 Fixo will probably help you out with a modified version using substr but for your info. (setq ans1 (substr textstring 1 9)) (setq ans2 (substr textstring 10 25)) (setq ans3 (substr textstring 26 39)) also (vla-setcolumnwidth objtable 0 15) ; 0 is first column 15 is width Quote
ramdi Posted November 24, 2015 Posted November 24, 2015 HOW MAKE BEAM SECTION DETAIL WITH LISP AUTOCAD Hello all. I have problems with AutoCAD. how to draw a detailed section beam quickly and correctly? , as supported beam left, center and right support which uses data from Excel or from ETABS. Please help. Thank you very much..,... Quote
