Import inventor 2009 drawings into Autocad 2002
We use AutoCad 2002 at work and have clients wanting to send Inventor 2009 drawings for us to edit. Can these drawings be imported in Autocad 2002 and what format do they have to be saved. I was told that there wasn't many options in Inventor to save files. If you know of a way to do this I would sure appreciate it. Thanks.:)
Not a problem, tell the guy using Inventor to click save as and select Autocad dwg, in the dia box click options and select Autocad 2000/ Lt2000.
Tried the "save as" Autocad dwg. Yes there is an option button, but---
it is dead. Won't open anything. I was told that other formats it would work.
