LISP Routine to change colour of all selected objects (except blocks)...?
Hey guys,
Just wondering if anyone could please advise me if they're aware of such a routine?
I am looking for a tool to change the colours of all selected objects. I am currently using routines such as:
(defun c:c2 () (ssget) (command "chprop" "p" "" "c" "2" "")(princ))
Which will easily change the colours of lines, plines, arcs, circles, text, etc. But I would also like to include objects which do not have such basic colour properties. For example, I would like to be able to change the text, dimension and extension line colours in the same routine as I would change a line colour.
Does anyone know of a routine capable of such a task?
I have just started writing some code to achieve this, but thought I would ask if anyone knows of an existing routine first.
Thanks a lot for any help.
Hi ,
The title of your thread is different than the content of it !.
Anyway try this to change the color of the Aligned & rotated dimensions .
(defun c:test (/ ss)
 (if (and (setq *clr* (acad_colordlg
                        (cond (*clr*)
                              (t (setq *clr* 256))
          (princ "\n Select Dimension to change their color :")
          (setq ss (ssget "_:L" '((0 . "*DIMENSION"))))
   ((lambda (x / sn)
      (while (setq sn (ssname ss (setq x (1+ x))))
        (if (vl-remove-if-not
              '(lambda (o) (and (eq (car o) 100) (wcmatch (cdr o) "AcDbAlignedDimension,AcDbRotatedDimension")))
              (entget sn)
          (mapcar '(lambda (e)
                     (vla-put-textcolor e *clr*)
                     (vla-put-extensionlinecolor e *clr*)
                     (vla-put-DimensionLineColor e *clr*)
                  (list (vlax-ename->vla-object sn))
     -1
(vl-load-com)
Thanks for the reply Tharwat,
I look forward to testing your routine when I get to work tomorrow. Sorry about the threat title. I would like to be able to create a routine to change colours of all objects, but dimensions are the priority at the moment.
For dimensions I would recommend to override the color of elements only if is already overridden; other adjust it by associated style.
You're welcome and hope it would suit your needs .
