115.jpgHi have this mission to sum the total length of lines between two others automatically , probably it has to be broken at intersection first, in the end i need the sum of lines between the two.
maybe the routine should transfer the lines to another layer first, or something similar that will make the difference
Thanks
Edited by danielk
You answered your own question, there is lots of total line length stuff out there it may need a extra bit of code say window and layer when filtering the selection set. Maybe start with www.Lee-mac.com routines pretty sure he has a total length lisp. I am sure he will help with a bit of recode to make it more explicit.
yep
;; Displays the total length of selected objects at the ;;
;; command line. ;;
;;--------------------=={ Total Length }==--------------------;;
;; Author: Lee Mac, Copyright © 2010 - www.lee-mac.com ;;
Thanks for the recommendation BIGAL :thumbsup:
@danielk, the following program should provide the lengths that you require:
([color=BLUE]defun[/color] c:intlen ( [color=BLUE]/[/color] app ent idx int lst obj rtn sel tmp )
   ([color=BLUE]while[/color]
       ([color=BLUE]progn[/color] ([color=BLUE]setvar[/color] 'errno 0) ([color=BLUE]setq[/color] ent ([color=BLUE]car[/color] ([color=BLUE]entsel[/color] [color=MAROON]"\nSelect polyline: "[/color])))
           ([color=BLUE]cond[/color]
               (   ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'errno))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nMissed, try again."[/color])
               (   ([color=BLUE]null[/color] ent) [color=BLUE]nil[/color])
               (   ([color=BLUE]/=[/color] [color=MAROON]"LWPOLYLINE"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 ([color=BLUE]entget[/color] ent))))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nSelected object is not a polyline."[/color])
   ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'ename ([color=BLUE]type[/color] ent))
           ([color=BLUE]setq[/color] lst ([color=BLUE]mapcar[/color] '[color=BLUE]cdr[/color] ([color=BLUE]vl-remove-if-not[/color] '([color=BLUE]lambda[/color] ( x ) ([color=BLUE]=[/color] 10 ([color=BLUE]car[/color] x))) ([color=BLUE]entget[/color] ent)))
                 lst ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( x ) ([color=BLUE]apply[/color] '[color=BLUE]mapcar[/color] ([color=BLUE]cons[/color] x lst))) '([color=BLUE]max[/color] [color=BLUE]min[/color]))
                 obj ([color=BLUE]vlax-ename->vla-object[/color] ent)
                 app ([color=BLUE]vlax-get-acad-object[/color])
           ([color=BLUE]apply[/color] '[color=BLUE]vla-zoomwindow[/color] ([color=BLUE]cons[/color] app ([color=BLUE]mapcar[/color] '[color=BLUE]vlax-3D-point[/color] ([color=BLUE]reverse[/color] lst))))
               ([color=BLUE]setq[/color] sel
                   ([color=BLUE]apply[/color] '[color=BLUE]ssget[/color]
                       ([color=BLUE]cons[/color] [color=MAROON]"_C"[/color]
                           ([color=BLUE]append[/color] ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( p ) ([color=BLUE]trans[/color] p 0 1)) lst)
                                       (0 . [color=MAROON]"ARC,CIRCLE,ELLIPSE,*LINE"[/color])
                                       (-4 . [color=MAROON]"<NOT"[/color])
                                           (-4 . [color=MAROON]"<AND"[/color])
                                               (0 . [color=MAROON]"POLYLINE"[/color]) (-4 . [color=MAROON]"&"[/color]) (70 . 80)
                                           (-4 . [color=MAROON]"AND>"[/color])
                                       (-4 . [color=MAROON]"NOT>"[/color])
                   ([color=BLUE]ssdel[/color] ent sel)
                   ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] idx ([color=BLUE]sslength[/color] sel))
                       ([color=BLUE]setq[/color] tmp
                               ([color=BLUE]vlax-invoke[/color] obj 'intersectwith
                                   ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]ssname[/color] sel ([color=BLUE]setq[/color] idx ([color=BLUE]1-[/color] idx))))
                                   [color=BLUE]acextendnone[/color]
                               tmp
           ([color=BLUE]vla-zoomprevious[/color] app)
           ([color=BLUE]repeat[/color] ([color=BLUE]/[/color] ([color=BLUE]length[/color] tmp) 3)
               ([color=BLUE]setq[/color] int ([color=BLUE]cons[/color] ([color=BLUE]vlax-curve-getclosestpointto[/color] ent ([color=BLUE]list[/color] ([color=BLUE]car[/color] tmp) ([color=BLUE]cadr[/color] tmp) ([color=BLUE]caddr[/color] tmp))) int)
                     tmp ([color=BLUE]cdddr[/color] tmp)
           ([color=BLUE]setq[/color] int  ([color=BLUE]vl-list*[/color] ([color=BLUE]vlax-curve-getstartpoint[/color] ent) ([color=BLUE]vlax-curve-getendpoint[/color] ent) int)
                 rtn '([color=BLUE]nil[/color] [color=BLUE]nil[/color])
               ([color=BLUE]function[/color]
                   ([color=BLUE]lambda[/color] ( a b )
                       ([color=BLUE]setq[/color] rtn ([color=BLUE]cons[/color] ([color=BLUE]cons[/color] ([color=BLUE]-[/color] b a) ([color=BLUE]cadr[/color] rtn)) ([color=BLUE]cdr[/color] ([color=BLUE]reverse[/color] rtn))))
               ([color=BLUE]setq[/color] int ([color=BLUE]vl-sort[/color] ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( x ) ([color=BLUE]vlax-curve-getdistatpoint[/color] ent x)) int) '[color=BLUE]<[/color]))
               ([color=BLUE]cdr[/color]  int)
              '([color=BLUE]lambda[/color] ( a b )
                   ([color=BLUE]alert[/color]
                       ([color=BLUE]strcat[/color]
                             [color=MAROON]"Length 1: "[/color] ([color=BLUE]rtos[/color] ([color=BLUE]apply[/color] '[color=BLUE]+[/color] a))
                           [color=MAROON]"\nLength 2: "[/color] ([color=BLUE]rtos[/color] ([color=BLUE]apply[/color] '[color=BLUE]+[/color] b))
               rtn
   ([color=BLUE]princ[/color])
([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color])
                               tmp
               rtn
thanks for your afford first, but i dont get length of the polyline between the two other polylines, i get two results and i dont understand forw what they refers to. i thought its the two length for each side of crossing , but if i checked it manually and its not the same results.
also the lisp doesnt prompt to check for two lines so the possibilty for more results is open. i hope you got my point..
Thanks
The following diagram should explain:
[ATTACH]49623[/ATTACH]
got it! :D genius as always!
Thank you so much!
