Simple153 Posted December 8, 2008 Posted December 8, 2008 I work for a house developer. We colour or site plans using Impression 2. When we have to send these to our printers they want them in PDF. When we convert from Impression 2 to PDF the file size increases in size quite dramatically to keep the quality suitable for printing. Our printers say the quality is fine but the file size is too large. Any ideas how to keep the quality but reduce file Cheers Si Quote
ReMark Posted December 8, 2008 Posted December 8, 2008 Yes. Optimize your PDF file size with a PDF compression utility. Should be able to dramatically reduce the file size without affecting quality. Quote
Dipali Posted December 8, 2008 Posted December 8, 2008 ask them if they can accept 'dwf'. tell them about dwf viewer & its free. dwf has file size lot smaller comapre to pdf Quote
wannabe Posted December 8, 2008 Posted December 8, 2008 The various PDF conversion printers differn in output file size quite drastically; which one are you using? The Autodesk PDF seems to be more unsympathetic than most. Quote
ReMark Posted December 8, 2008 Posted December 8, 2008 Luratech.com has a program called LuraDocument, a PDF compressor. Free trial available. cvisiontech.com has a program called pdfcompressor. Free trial available. And BureauSoft has a freeware program called PDF Compress. Maybe you could try "zipping" the file using WinZip or pkZip. Quote
f700es Posted December 8, 2008 Posted December 8, 2008 How big are you .irf files? I made a real quick one at 676k and made a 300 DPI PDF and it was only 420k. I did Acrobat full though. Quote
