broken alignment references
So I'm running c3d 2013 on a win7 64x machine.
When I open my drawing I see the text broken reference to aeccdbalignment...
Then I go into toolspace, find my offending alignment, rightclick and choose 'repair' i get the message object not found
What my problem is when I go into my source drawing is that the alignment is there and is unchanged.
When I go to data shortcuts I can create references to that same alignment just fine but what I really need to do is find a way to restore the original alignment because I have a bunch of profile views that reference it.
Is this possible or am i SOL?
If the profile still shows your design elevation - such as for a roadway, existing ground etc then your alignment is still there. It may be on a off layer???
If not then the alignment has been exploded and will need to be recreated.
