ramale Posted June 16, 2014 Posted June 16, 2014 I need to Draw Double line 2D Flexible and Single line Flexible,I want Radially bent flex in curve and straight flex in straight path.Please help me with .Lsp File. I have attested here with the Sample Drawing which i need. lsp.pdf Quote
Pietari Posted June 16, 2014 Posted June 16, 2014 We all need so much more. Please post your attempts so far. Quote
ramale Posted June 17, 2014 Author Posted June 17, 2014 Dear Sir, We did not use any Auto.Lisp file yet for the flex construction. But Long term using CAD and to Draw Flex its too late and we want newly to draw. So we tried one of Auto.lisp file for flex line just before which could not fill up our requirement at turning by radially. I have attested herewith Exactly which i need exactly: Attested= 1. Auto CAD File .DWG(which i draw with .Lsp file and needed) 2. Auto.Lisp File (which i uploaded for flex line drawing) 3. .PDF File ( Just sample taken from Auto-CAD) Best Regards Ram Ale 009779849083501 Drawing.pdf FLEXIBLE.LSP Flex Drawing.dwg Quote
Pietari Posted June 20, 2014 Posted June 20, 2014 Can't help you with this one, sorry. It is too time consuming for me and maybe too complex as well. Good luck. Quote
ramale Posted June 22, 2014 Author Posted June 22, 2014 Dear Sir, Thank you for your kindly help to searching. Please sir, I need just Single line 2D flex with radius at turning point and straight flex unless it seems curve. Quote
Dadgad Posted June 22, 2014 Posted June 22, 2014 Welcome to the CADTutor forum. You might want to EDIT, to delete your phone number from your previous post, lest the Bots get a hold of it, and your phone number is ringing off the hook 24/7. I am too busy right now to delve too deeply into your question, but it occurs to me that you could do this quite simply, by creating custom MULTILINE styles to represent your different types of flex. There are a number of different interesting definition options to consider in the Multiline Dialog box. These can be real timesavers, and are quite simple to define and create. Once Saved, they will be available another time for use, on the fly. Quote
ramale Posted June 23, 2014 Author Posted June 23, 2014 Dear Sir, I want to Draw Polyline 2D flexible with different radius as per Curved angle( if possible Radius within 100-250). I have attested here with .pdf file and Auto-CAD Drawing File which i need.Please kindly look. Best Regards Ram ale PolyLine 2D Flexible.pdf Single Line 2D Flexible.dwg Quote
Tiger Posted July 31, 2014 Posted July 31, 2014 Hi Ramale, I have deleted your duplicate question in the News-section, please do not tack your question on to an old thread. You got one suggestion from Lee Mac there, that I will link to here: http://www.cadtutor.net/forum/showthread.php?30545-*FREE*-HVAC-or-Piping-program-for-AutoCAD Quote
ramale Posted November 4, 2014 Author Posted November 4, 2014 hi,Tiger, Thank you for your valuable message and link which solved my problem. Quote
