tplight Posted June 20, 2014 Posted June 20, 2014 We have always used a custom wall type and have always infilled the area between any walls that have a void for presentation purposes. Release 2014 has been causing problems as the infill area still has a faint outline after applying the wall merge. The walls are the same height, are the same style and draw order has also been applied. Does anybody have any suggestions as to how we can remove the lines between the infill and the surrounding walls? Thank you. SCAN0615_000.pdf Quote
