hosyn Posted June 22, 2014 Posted June 22, 2014 Which way for controlling the Text Size on your Tool Palettes in autocad? Quote
Dadgad Posted June 23, 2014 Posted June 23, 2014 I am not sure if this is what you are looking for, but likely. In OPTIONS on the DISPLAY tab. One is for the ribbon, and the other for toolbars. If you are really looking for text size on the tool palletes, I just checked, and even in the properties, there does not seem to be a way to adjust them. Quote
nestly Posted June 23, 2014 Posted June 23, 2014 I think the OP is trying to put a tool on the Tool Palette that will fix the height of the mtext when inserted from the tool palette. I suppose that would be done by changing the macro to specify the text "Height" Quote
hosyn Posted June 23, 2014 Author Posted June 23, 2014 At this page describe how we can change : http://lynn.blogs.com/lynn_allens_blog/2005/10/a_tip_for_contr.html But unfortunately i don't understand that explain clearly ,,any help ?? Quote
Dadgad Posted June 23, 2014 Posted June 23, 2014 Go to your Desktop (not in Autocad, but on your computer) and right click to access the Display settings, once you are into that menu, you should be able to find where you adjust the text display size. Quote
