dme Posted June 29, 2014 Posted June 29, 2014 Hi I'm new to AutoCAD. I'm trying to make a inlet pipe of radius 160 (ILRU160) I have been trying with two circles and an arc and the use the command LOFT. Is this the right way? Please give me some ideas. Thanks Quote
JD Mather Posted June 29, 2014 Posted June 29, 2014 Revolve sounds easier. Can you attach your dwg file here? Quote
dme Posted June 30, 2014 Author Posted June 30, 2014 Thanks for the tip. Revolve was the solution :-) Quote
BIGAL Posted July 1, 2014 Posted July 1, 2014 Have you tried a pline with c/l radius draw a circle = dia pipe, use rotate3d to rotate circle sq to end of pline use a 3d view to see whats going on vpoint 1,1,1 then Extrude circle path. Quote
