I am receiving this error when trying to use the Cut feature in Extrude:
Create extruded feature failed
bt10010_0000_001_rev_b.ipt: Errors occurred during update
Extrusion4: Could not build this Extrusion
The attempted operation did not produce meaningful intersection edges from the face-face intersection. Try with different inputs.
Any insight would be greatly appreciated. Thanks.
Cut Error.ipt
I recommend starting over from the beginning.
Why are there no dimensions. (when I add the dimensions - they don't make logical sense)
Where did the sketches come from? (look like incorrectly done AutoCAD sketches)
I started to do this one over from scratch - but there are so many errors that I gave up.
If you can clean up the sketches (only need top, front and side sketches) I can continue and show you how I would model the part.
It was a drawing that was done in Cadra. I had to open it in autocad and fix some things before I was able to use it. I will draw up the sketches ASAP. Thanks.
