What's the problem in my code, i wanna to copy object with displacement 100
(command "copy" "d" "100")
Indeed when i run the command lisp select objects and copy in certain displacement
Any help please.:?
Your question is a very simple one and I am pretty sure I have suggested previously that you invest some time in learning lisp, buy a book or look at the online tutorials. It seems to me that your using the site for I can not be bothered to spend any time learning some else do the research. As a answer look at ENTSEL.
(if (setq s (ssget "_:L"))
   (command "_.copy" s "" "_d" "_non" '(100.0 0.0 0.0))
ThanxXXXXXXXXXX a lot Mr lee that's ok and if i wanna delete the origin objects store in s at
after the ranning code I added the
(command "_erase" s)
but dont do well it ,any suggestion??:unsure:
You miss an "".
Should write (command "_erase" s "")
An "" is like an Enter at the command line.
I belive that it is better to use MOVE instead of copy then delete.
Hosyn have a think about 3 little lisps chx chy chz these do what you want moving an object in 1 plane direction. Either ask for distance or maybe have some predefined chx100 chy100 you make the pick a loop so can do repeated times and pick multiple objects. I can not post code copyrited.
