Importing an AutoCAD Map into Mapsource
I have a map which can open in AutoCAD (.dwg) I would like to have it open in Mapsource so that I can later download it to my Garmin GPSMAP60CSX. How do i do this??
I am not sure about this process (especially if you do not have Autocad Map).
But there is another way if you have access to ESRI ArcGIS software.
An add-on is avaliable called DNR Garmin (from the Minnesota DNR for free) that links ArcMap with Garmin handheld GPS units.
