danielk Posted July 16, 2014 Posted July 16, 2014 Hi when i get files coming from solidworks, autocad is slow even when i hover above (before even selecting ) the entity , this thing makes the workflow a real problem . is there any trick to overcome this one? *i have hardware acceleration on. *i have super strong machine (almost the best you can get). *all my drivers are up to date *i have wscommcenter disabled Thanks Quote
JD Mather Posted July 20, 2014 Posted July 20, 2014 How big are the files? Lots of parts? Xref? Quote
danielk Posted July 21, 2014 Author Posted July 21, 2014 files vary from 2mb to 30mb , no matter what size, the lagging happens in each file contain blocks import from solidworks. even in files of 30 parts total (5 files import) Quote
JD Mather Posted July 21, 2014 Posted July 21, 2014 ...the lagging happens in each file contain blocks import from solidworks. ... Zip and attach example here. Quote
danielk Posted July 23, 2014 Author Posted July 23, 2014 Try In shaded mode (move, copy, rotate),although it happens in wireframe also https://drive.google.com/file/d/0BxeDB29-vmoaZTZqSzZ6UTI3WGs/edit?usp=sharing Thanks Quote
