Is there a way with touch a block select similar block in selected reign of drawing?
Is there a way with touch a block select automatically similar block in selected reign of drawing via lisp code or command similar select? 8)
hi hosyn, i'm not sure your meaning of touching,
Try this simple dxf filter function,
(issget e i); argument e=reference entity & i=dxf index to be filtered
;Single dxf index-match ssget filter
(defun issget  (_e _id / ss i e1 e2 lst ss1 next)
 (if
 (not (setq ss (ssget)))
         (setq ss(ssget "X")))
 (if ss (progn
 (setq i 0)
 (repeat (sslength ss)
   (setq e1 (ssname ss i))
   (if (apply 'equal
              (foreach en  (list e1 _e )
                (setq lst (cons (mapcar '(lambda (x) (cdr (assoc x (entget en)))) (list 0 _id))
                                lst)) 		;setq
                ) 				;foreach
              ) 				;apply
   (setq ss1 (cons e1 ss1))
     ) 					;if
   (setq i  (1+ i)
         lst nil))				;repeat
 (setq next (ssadd))
 (foreach e2 ss1 (ssadd e2 next)) 		;foreach
 )						;progn
 nil)						;if
  ) ; defun
Example: Just pick a single entity, then [ENTER] ,or manually select
_$ (sslength (issget (car(entsel)) 8 )) ;
44 ;
Simple
(setq obj (entsel "pick block"))
(setq bname (assoc 2 (entget (car obj)))
(princ bname)
; just use bname in a ssget filter now.
