KTS Posted July 22, 2014 Posted July 22, 2014 Hi there, I have a dwg in model space with a building foundation block in it. I however can't view the block in my layout/paper space. layout scale is 1:40. When I explode the block in model space, then it becomes visible in the layouts. No layers are frozen in either model or paper space. Any ideas Thanks Quote
Ski_Me Posted July 22, 2014 Posted July 22, 2014 check to see if your block is annotative and make sure you check the show current annotation box from your layout. had the same issue awhile back and that fixed it. worth a shot. Quote
RobDraw Posted July 23, 2014 Posted July 23, 2014 No layers are frozen in either model or paper space. How about the viewport? Quote
KTS Posted August 17, 2014 Author Posted August 17, 2014 Thanks Ski, Problem solved. Sorry about the late reply Quote
