Trying to use design accelerator for a bevel gear
Hey guys, im having an issue creating a bevel gear to my required specs without a design failure.
I need the smaller gear to have 7 teeth with a diameter of 5mm or so.
the second gear can be larger but i need around 50-70mm diameter.
when i designed the spur gear i could choose input type however for this bevel gear all i can do is set the gear ratio and the module and hope for the best.
any advice on how to go about this is greatly appreciated!
I would have posted this question in the Inventor forum.
You are more likely to get a solution there.
