Armin M
Inventor 2015 - Sheet Metal -C reate Flat Pattern from sweep along path
Armin M
Hello there,
I have a specific problem creating a flatt Pattern from an Sheet Metal Part. My question is:
Is it possible by the nature of the material and geometry to create such an flat pattern? Notice the Sweep Path has an circular sector. If it is possible, how can I do that , since I'm a newbie to the World of Sheet Metal :).
Thank you :)
Armin M.
Alu Sheet.ipt
Share this post
Link to post
JD Mather
Contour Flange and Contour Roll will be your friend.
Share this post
Link to post
Armin M
Such an simple answer and it performed extremely well. Thank you.
Share this post
Link to post
JD Mather
Glad you figured it out - I intended to post example and then forgot.
Share this post
Link to post
Armin M
No Biggie, found numerous examples of the command usages on youtube. :)
Share this post
Link to post
