sw987 Posted December 10, 2008 Posted December 10, 2008 I am using Acad 2006 version. My prob is with viewport i have set a viewport in some particular scale & locked the viewport. But when any command is active & i scroll for zoom in & out the scale automatically change in the viewport. this is happening with all of my files not for a singe file. i tried it a lot in in my system, some outer system it is not happening. Is there any problem in settigs ? Quote
wannabe Posted December 10, 2008 Posted December 10, 2008 You mean when you activate the viewport whilst in a layout? I get that, too. Quote
sw987 Posted December 15, 2008 Author Posted December 15, 2008 I am using Acad 2006 version. My prob is with viewport i have set a viewport in some particular scale & locked the viewport. But when any command is active & i scroll for zoom in & out the scale automatically change in the viewport. this is happening with all of my files not for a singe file. i tried it a lot in in my system, some outer system it is not happening. Is there any problem in settigs ? Please F1 me.. Quote
succu8us Posted December 15, 2008 Posted December 15, 2008 on the paperspace activate the viewport and set the UCSVP=0 Quote
DKOU812 Posted December 15, 2008 Posted December 15, 2008 Select VP window, and verify property window is lock layer state (def points). Locking down the same layer will help too. Quote
smorales02 Posted December 15, 2008 Posted December 15, 2008 how are you going about locking your VP? Quote
DKOU812 Posted December 15, 2008 Posted December 15, 2008 The VP property is display locked off/on. This is only set when the VP layer itself is selected in PS. Be sure the VP is not engaged. Is Land Desktop an Autodesk Suite to AutoCAD? Quote
